Old 02-24-2016, 05:14 PM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default Converted V12 Distributor
Taking apart this old V12 distributor that has been converted for a V8. Noticed all the caked on red dirt. Makes me think it probably once ran the dirt round tracks of days gone by.
Old 02-24-2016, 06:04 PM   #2
Vic Piano
Vic Piano's Avatar
Default Re: Converted V12 Distributor
Very cool.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 02-24-2016, 07:18 PM   #3
Fordestes
Keep us posted on progress, Are you using a modified dist. rotor or a modified dist. cam ? I want to find someone to grind the dist. cams, I found one dist. with all the lobes still on the cam and the wire contact plates were soldered with strips, I am almost afraid I will mess up on the cams, the red dirt must be from an Okie car, nearly all our dirt is red. L.O.L
Fordestes
Fordestes is offline   Reply With Quote
Old 02-24-2016, 07:32 PM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Back in 1955 a few of us boys had a 39 coupe we ran at Sanford drags. I remember getting one of the those V12 dist, I remember it had special rotor. I know we had a hard time getting the plug wires into the right cap holes. Arrrr the good old days. Walt
Old 02-24-2016, 07:47 PM   #5
Ken/Alabama
There is a really good article printed in the 1955 Hot Rod Anual about converting the V12 distributor. It appears that the one I have has been done by those instructions. My plan is to rebuild it and I have a 99A Merc block and a L100 cam and put it in my 40 coupe.
Old 02-24-2016, 07:55 PM   #6
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Fordestes
I have the Hot Rod drawings for the conversions. Three seperate books , drawings are pretty good on the cam machining..
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 02-25-2016, 06:31 AM   #7
JWL
I used a V8 cam and simply removed every other lobe. I don't remember what was necessary to make it fit or work.
JWL
JWL is offline   Reply With Quote
Old 02-25-2016, 07:36 AM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
Question to JWL and Bubba.......
Could the 4 lobe camshaft from a Harmon - Collins dual point, dual coil, distributor (same aluminum housing body used by Ford for '42-'48 crab) be used as a "machining guide" for making a special four lobe camshaft from a stock '41 helmet distributor camshaft, that would fit and work in converting the Lincoln V12 distributor to a dual coil, dual point V-8 distributor?
John
Old 02-25-2016, 10:41 AM   #9
BUBBAS IGNITION
Guys,
This is a good discussion regarding the V12 to Flathead conversion. I have the April, May and June Car Craft 1954 ( available on ebay) and there seems to be more to it than we have discussed...
Seems like a lot of work to me ...
Heres a couple scan for today. Maybe we could make this a complete post for all to see if theres interest....???
[email protected]
Old 02-25-2016, 10:55 AM   #10
BUBBAS IGNITION
Looking at the plans :
1-cut slot for wires back of coil
2-opening for point plate for use of ford plate
3-lengthen the point plate boss on rear base housing
4-modify rotor mount
5-grind cam lobes
6-brass straps on side caps
7-remove 1/32 from rotor tips
8-modify point plate for bendix points9-modify timing tab
9-modify (wire) lincoln coil
10-sync and adjust on machine....
[email protected]
Old 02-25-2016, 01:37 PM   #11
D. Jones
D. Jones's Avatar
I was never in to racing or hot-rods so I've never heard of this conversion.What was the advantage over a stock Ford distributor? I assume it was something like better control of the timing curve, or possible longer dwell.
D. Jones is offline   Reply With Quote
Old 02-25-2016, 03:20 PM   #12
BUBBAS IGNITION
Good question , ya got to take into account the timing ( no pun intended) of the project. Its 1953 and the flathead is still king , theres no chevy V8 and few olds V8s etc . So its really about the flathead. The factory ignitions were pretty limited in regards to rpm supplying proper spark.. Assuming you had a flathead that could run above 5000 rpm you had a issue.
The lincoln conversion provided the fix for the issue by using two coils firing 4 cylinders each. More time to build up on each cylinder allowed the unit to run a much higher rpm. I have ran the Lincoln conversion at 7000 rpm and above with no spark scatter what so ever.... A very good fix for the time period it was used .
[email protected]
Old 02-25-2016, 03:59 PM   #13
Andy
How about this?
Andy is online now   Reply With Quote
Old 02-25-2016, 04:18 PM   #14
Kerk
How would that compare to a restored Harmon Collins if they can be rebuilt. Have a complete one as removed from my 32 that was supposedly run at Sanford, Me. It is presently a wall hanger ! Kerk
Kerk is offline   Reply With Quote
Old 02-25-2016, 04:24 PM   #15
Bruce Lancaster
Bibliographic note...the Car Craft articles and the writeup in the '55 yearbook are the same. The Car Craft article is the desirable one, as the reduced the size of the drilling template in the Annual, rendering it pretty close to useless.
Old 02-25-2016, 04:41 PM   #16
Ken/Alabama
5-grind cam lobes
Hey Bubba, Are those Bendix points still available anywhere?
Old 02-25-2016, 05:03 PM   #17
BUBBAS IGNITION
Originally Posted by Andy View Post
How about this?
Thats a different way to get it done....
[email protected]
Old 02-25-2016, 05:04 PM   #18
BUBBAS IGNITION
Yes, i have them they are $104 per pair...
[email protected]
Old 02-25-2016, 05:07 PM   #19
BUBBAS IGNITION
Actually the comparison would be "visual" only the harmon collins is a good unit as well......twin coil ( two four cylinder set ups)....
Side note : Going after rpm in these is no problem , however going after high output from the coil dont work as it breaks down the insulation really easy !!!!
[email protected]
Old 02-25-2016, 08:16 PM   #20
KiWinUS
KiWinUS's Avatar
This is all very interesting to me , I had a LZ dizzy that had been converted to a v8 but made the mistake of selling it some years ago . I now have a stock LZ & have been gathering info on converting it to a v8.
This is great !!!
Cheers
Tony
