Old 02-14-2016, 02:04 PM   #1
nuwala
nuwala's Avatar
Default best cure for vertical play on rear axle ?
I have difficulties adjusting the rear brakes and believe the cause in the rear axle play. Most of the times brake drums get hot, despite the wheels spinning free without brake fiction when car is lifted. The temperature of the drums is measured with infrared thermometer to approx 250°F - 300°F when driving.
Left and right is about the same play in the axle, all measured with the hubs and drums mounted, and hub nut tight with 100Nm:
- vertical play - wheel up/down is 0,08"
- horizontal play - wheel forward/backward is 0,02"
- axial play - wheel in/out is 0,06"
What worries me is that difference in horizontal and vertical play. I have removed the hub and measured the diameter of axle race both in a horizontal, and in a vertical. The difference between horizontal and vertical was less than 0,04". So there is another 0,04" missing?
- What would be your recommendation?
- Time to change the rear bearings?
- Shall the axle race be changed as well? How to remove the old and install the new race? Can his be done with the axle still mounted?
nuwala is offline   Reply With Quote
Old 02-14-2016, 02:14 PM   #2
JohnB15632
JohnB15632's Avatar
Default Re: best cure for vertical play on rear axle ?
One thing that I may suggest, but I am not sure. I myself have to figure this out. Braking between the front and rear is 40% front, 60% rear. Is it possible that the brake arms need to be adjusted to obtain this balance? Just a guess on my part.
JohnB15632 is offline   Reply With Quote
Old 02-14-2016, 02:29 PM   #3
Mikeinnj
Mikeinnj's Avatar
Unfortunately the race on the end of the axle housings must be turned down on a lathe and a new race pressed on.
Mikeinnj is offline   Reply With Quote
Old 02-14-2016, 02:44 PM   #4
tbirdtbird
" Is it possible that the brake arms need to be adjusted to obtain this balance?"
no
Purdy Swoft covered the difference between adjusting with wgt on and off the wheels several times here over the years
A search may be revealing
'31 180A
tbirdtbird is offline   Reply With Quote
Old 02-14-2016, 03:27 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Is that high temperature after a hard braking, or after coasting to a stop?
If coasting, then the brakes are dragging way too much. Even after a normal stop they shouldn't get that hot.
Old 02-14-2016, 04:31 PM   #6
Synchro909
Synchro909's Avatar
Who ever wrote the description in the attachment to the original post clearly doesn't know the difference between inside and outside nor top from bottom. The last sentence also makes no sense - unless I'm missing something but I've seen instructions from vendors laughably wrong on many occasions.
Does anybody else think this description is nonsense?
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 02-14-2016, 04:37 PM   #7
nuwala
nuwala's Avatar
The temperature of the rear drums go up to 250°F - 300°F when driving a 40mph for about 10 min and slowly braking. Front wheels go up to 90°F and never exceed 120°F
Old 02-14-2016, 05:15 PM   #8
Tom Wesenberg
I would back off on the rear adjusters a couple notches, then try it again.
Old 02-14-2016, 05:29 PM   #9
nuwala
nuwala's Avatar
Thanks Tom,
It does not really help to open the adjusters, i ve tried that before. The drums get even warmer when opening 5 to 10 notches. More than 10 notches and the rear brakes dont work.
And apologies for my English, it's challenging for a non native to find the right technical terms.
Old 02-14-2016, 05:37 PM   #10
Brentwood Bob
What is the condition of the rear inner and outer hub bearings?
Bob
Brentwood Bob is offline   Reply With Quote
Old 02-14-2016, 05:42 PM   #11
Pinesdune
Pinesdune's Avatar
Yeah it sounds like your rear brakes are dragging bad.
There are three areas for wear in the rear hub assembly: the hub wears internally, the stub on the axel housing as in post 3, and the bearing. So that's where your free play is coming from (except axel end play is internal in the diff)
Other guys are more knowledgeable on brakes than me here, but I'd say somethings sticking and not allowing your brakes to release hence the high temps on the drums
Looking for the front bumper emblem that has "Ford, Made In Canada"
Pinesdune is offline   Reply With Quote
Old 02-14-2016, 05:46 PM   #12
nuwala
nuwala's Avatar
The bearings look fine at the first glance. I've cleaned and greased the bearings but have not removed it for the hub yet. Bearings seem to be original since there is still the original 1929 shaft seal.
Old 02-14-2016, 06:08 PM   #13
Tom Wesenberg
I would remove the rear hubs and look for something dragging. Backing the adjusters off should let the drums turn freely.
Old 02-14-2016, 06:09 PM   #14
700rpm
700rpm's Avatar
Can you take your hubs to a brake shop and check them for runout? Maybe they're thin and out of round?
Or,
Können Sie Ihre Naben zu einem Brems-Shop und auf Rundlauf prüfen? Vielleicht sind sie dünn und aus der Runde?
Your English is fine, by the way. How's my German?
Ray Horton, Portland, OR
Old 02-14-2016, 07:32 PM   #15
DougT
How is the emergency brake adjustment? It would do the same thing.0
DougT is offline   Reply With Quote
Old 02-15-2016, 12:23 AM   #16
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
If it was the emergency brakes dragging, then that part of the drum (smaller front) would be hotter then the service brake area, (larger back).
Old 02-15-2016, 04:15 AM   #17
wensum
wensum's Avatar
I used the kit below with success which provides a sleeve to glue over the existing bearing surface and a new set of bearings with smaller rollers but the same outer diameter.
Keith
http://www.macsautoparts.com/ford_model_a/model-a-ford-rear-wheel-hub-race-repair-kit.html
wensum is offline   Reply With Quote
Old 02-15-2016, 04:51 AM   #18
harleytoprock
Wensum, That kit restores the bearing surface in the hub.That bearing has the same ID as original and won't help a worn race on axle housing. The op may need this kit to restore the hubs if worn as well as the axle housing press on sleeve if that also worn.
Syncro909, If your refering to the attached vendor description for the rear axle housing race, I don't see any errors. It makes perfect sense. That race is pressed on the housing.
harleytoprock is offline   Reply With Quote
Old 02-15-2016, 08:25 AM   #19
Pinesdune
Pinesdune's Avatar
Quick question, how much tilt can you get out of an assembled rear wheel assembly. IE. With everything together, if you grab the rear tire at the top or bottom and try to push it in towards the car and then pull it out, how much, if any, does the tire move?
Old 02-15-2016, 04:17 PM   #20
nuwala
nuwala's Avatar
The shoes only heat the inner brake shoe areas of the drum, emergency brake areas of the drum remain colder.
There is about 0.2" tilt with all assembled and full released brake shoes (adjuster out). The tilt is difficult to measure, as tilt and lift combine when moving the rear wheel.
When brake adjusters are tightened the tilt reduces to less than measurable.
After a sleepless night I was thinking of:
- Maybe it would help putting little grease into the brake shoe rollers?
- changing the retracing springs to add more force moving the shoes into the normal position?
- adjusting the brakes with standard car weight on wheels and axle rather that wheels lifter. This to be done on two barrels, similar to test stands for brakes?
