Old 06-10-2016, 05:32 PM   #1
1949f1
Default Heat!
So I've been doing some work on my 53 merc. I've got new thermostats water pumps and I've had the radiator boiled out. I've got a infared thermometer and the heads around the spark plugs are reading around 190. The center at the 8cm is reading 200. Is this about right? The heat gauge is running above three quarters on the stock guage. I have 160 thermostat in it. Thanks!
1949f1 is offline   Reply With Quote
Old 06-10-2016, 06:04 PM   #2
39topless
Default Re: Heat!
You're cool!
39topless is offline   Reply With Quote
Old 06-10-2016, 06:07 PM   #3
1949f1
Default Re: Heat!
Thanks! I'm guessing my gauge is wrong? I'm trying to figure out a way to hide an aftermarket guage. Thinking maybe a bracket or something to flip up to hide.
Old 06-10-2016, 07:14 PM   #4
Mike in AZ
Mike in AZ's Avatar
Default Re: Heat!
maybe a mechanical gauge from each head mounted on a flip up panel as you said.....Mike
Mike in AZ is offline   Reply With Quote
Old 06-10-2016, 07:27 PM   #5
1949f1
Default Re: Heat!
That's what I was thinking according to the gun it's running 10 degrees colder on the passenger side head. I was hoping that it was the guage I couldn't imagine it was anything else. The guage is reading all the way up to 4 quarters.
Old 06-10-2016, 08:40 PM   #6
tubman
tubman's Avatar
Default Re: Heat!
I don't have any overheating problems with my '51, but when I got my new infrared thermometer, I read all over the engine, and also found the passenger side was running 10 degrees cooler I think it may have something to do with the heater being on that side, although it wasn't on when I did my checking. Weird.
Old 06-10-2016, 10:21 PM   #7
my4dv8
Default Re: Heat!
You could hide a gauge behind the sun visor or in the glove box.
my4dv8 is offline   Reply With Quote
Old 06-10-2016, 10:22 PM   #8
RalphG
RalphG's Avatar
Default Re: Heat!
Just for comparison I checked my 52 Merc tonight after a good hard quarter mile test run.. The digital infra red showed about 160 on the passenger side head and 170 to 180 on the left side. Heater core is disconnected on this one so not sure why one side would run hotter. Temp gauge on this one usually runs about dead centre or a shade above. No thermostats.
RalphG is offline   Reply With Quote
Old 06-10-2016, 10:26 PM   #9
19Fordy
19Fordy's Avatar
Default Re: Heat!
Your temps are fine. If it don't boil, you are good to go.
Plus, the ambiant temperature in MS is higher than many other states.
Old 06-11-2016, 04:33 AM   #10
41LjH
41LjH's Avatar
Default Re: Heat!
consider pulling the sending units and either cleaning or replacing them. Also ground the gauge and look for full deflection. Normally the gauge doesn't need calibration. Remember the wiring is over 60 years old!
3 pedals, 3 gears, no valve-covers..
Now THAT is a hot rod !!
https://www.youtube.com/watch?v=ZmwwB34vxJE
41LjH is offline   Reply With Quote
Old 06-11-2016, 05:51 PM   #11
1949f1
Default Re: Heat!
I don't know which is worse 60 year old wiring or A J.C. Whitney harness😂😂
Old 06-11-2016, 07:22 PM   #12
Ross F-1
Ross F-1's Avatar
Default Re: Heat!
Here are readings I took on my engine after a long pull up a hill in 95 deg weather
Location.................... temp
Top tank ....................173-179
DS head (center).............183
PS head (center)..............183
DS thermostat housing .....173
PS thermostat housing.......179
All using an infrared laser heat gun. My dash gauge reads a needle width above center, that's on a 12-to-6 volt converter.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 06-11-2016, 10:24 PM   #13
1949f1
Default Re: Heat!
That's close maybe 10 degrees higher on everything. And like a previous poster said idk about where you live but it's 90 degrees here
Old 06-11-2016, 10:25 PM   #14
1949f1
Default Re: Heat!
Thanks all for the replies I'm going to play with the heat gauge as suggested and see what I get.
