Got to get those lug nuts loose first.
She must be straightening a bent spoke with that monkey wrench.
BTW, how did it ever come to be called a monkey wrench? |
These are also known as a Ford wrench owing to this type of wrench being included in the tool kit supplied with every Ford Model A.
https://en.wikipedia.org/wiki/Monkey_wrench Last edited by bunnyc; 02-17-2016 at 12:06 PM. |
Had I been driving by that day, I would have gladly stopped to lend a helping hand.
Ifn I had of been driving by I probably would have ended up in the ditch if not something worse.
Because when I clock you with it, you'll run around like a monkey
![]() ![]() or because only Monkey's would use one to strip a bolt.
Blackwall Panthers Nor Cal chapter |
Lot's of female Model A mechanic's out there, you think I do this for just the fun and excitement?
The moto meter tester is a bit much tho
Invented by Charles "Moncky"!
www.whidbeymodelaclub.com |
That might be a widow maker!
