Old 01-08-2016, 03:05 PM   #1
bartmcneill
bartmcneill's Avatar
Default Need to assemble coupe - any instructions?
Just go my 30 coupe home and placed in storage until I begin assembly. I am thinking I should get each metal piece or section in good shape before I assemble it. Are they any good books on assembling the body correctly. The metal is really good and I want it to go together with no future worries about rust, etc. The subframe is new and already together.
bartmcneill is offline   Reply With Quote
Old 01-08-2016, 04:06 PM   #2
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: Need to assemble coupe - any instructions?
Wow looks like you have enough for two coupes, or at least a coupe and a half!
I'd start by checking each piece over for damage, and make notes. Surf for photos of other assemblies going together. Ask a lot of questions before you set the first rivet or weld. Make sure its fun, and if its not stop and rest.
Good luck!
Farrell In Vancouver is offline   Reply With Quote
Old 01-08-2016, 04:26 PM   #3
Kevin in NJ
The rumble stops do not attach with all 4 bolts into the rumble riser.
See my website for detail pictures. Make sure the brace underneath is welded to the riser.
My advice for order.
Make frame straight and then level it.
Get running board brackets properly set.
Get front fender brackets fitted to the headlamp bar.
Make front fenders fit to the running boards and such.
Build body on frame.
Make hood fit.
Fit rear fenders to the body/ running boards.
Now start painting and building the chassis and body.
As far a building the body. Well if it works right and is level and even then you have it right. The body will likely build itself if pay attention to center lines and absolute must fit stuff. I was worried about knowing a lot of details when I started building my cabriolet. Turns out I worried too much. The coupe is 100 times easier to build I am sure. Just use common sense and take your time. Besure to do a full tight mock up of everything together so there are no surprises after paint.
Old 01-08-2016, 04:52 PM   #4
Rowdy
No instructions, but looks like time to buy some cleco clamps. Assemble it with those to see what needs done and what might be missing. Looks like fun to me. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 01-09-2016, 01:03 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
Wow!!
A lot is going to depend on how they (you?) took it apart.
Second guess nothing!. Build it on the frame of course and ask here often for measurements. As for work before assembly, I would think not. Since part A fits to part B; welding, sanding, hammering, will change the shape and make the assembly more difficult than it has to be for you.
Good luck, post pictures of the build for us and do not be afraid to ask ANY question you think you need to ask.
Old 01-09-2016, 07:40 PM   #6
bartmcneill
Ford Garage site is really good. I guess I will have to purchase a top wood kit in order to get the coupe sides lined up as they should be. The site below is one I had forgotten about and will help those like me. I don't think assembling the coupe body will be rocket science but I will take my time to get it right. I want this body to last many years so my grandson can pass it down to his grandson.
http://www.cabriolet.modelahouse.com...ures?other.txt
Old 01-09-2016, 08:30 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
How to assemble? As Johnny Cash would say, "ONE PIECE AT A TIME"!
Bill Okie
"THE ASSISTANT GURU OF STUFF"
