Old 12-25-2015, 05:06 PM   #1
Larry Jenkins
Default Using Mitch's suggestion, I made one..
In an earlier post, I stated I was having trouble removing the center tube from my hood. Mitch showed me a set of driver rods, so here's what I made.
Using one of the original 1/4" solid side rods (which are actually 0.256, not 0.250,) I turned down one end to 7/32" diameter by 1/2" long on my metal lathe.
Using a short piece of brass rod, I drilled a 7/32" hole in it. Cut it off to 1/2" long and pressed the brass onto the end of the rod.
Chucked up the rod with the brass end about 2" away from the chuck jaws and turned the outside of the brass sleeve to 0.375.
Inserted the home made "Mitch Driver" into the hollow tube (nice snug fit)
and tapped the tube out pretty easily. By using the center rod full length, I could tap it out all the way without pulling or spinning.
Yes, you do need a metal lathe with a 3 jaw chuck.
Thank you, Sir!
Larry
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 12-25-2015, 05:23 PM   #2
ericr
ericr's Avatar
Default Re: Using Mitch's suggestion, I made one..
don't such lathes cost in the thousands?
ericr is offline   Reply With Quote
Old 12-25-2015, 07:15 PM   #3
2manycars
2manycars's Avatar
Look for a used one. Mine cost $300.
2manycars is offline   Reply With Quote
Old 12-25-2015, 07:31 PM   #4
Larry Jenkins
As stated, used one's are pretty reasonable.
Get at least a 4" swing one. Mine was used for $200. And it has power feed longitudinally both ways. So many Model A parts can be reworked. I polish anything round. Makes 'em look purdy..
Larry
Old 12-25-2015, 08:16 PM   #5
Mitch//pa
nice job Larry post pic of it
Old 12-25-2015, 08:23 PM   #6
Larry Jenkins
Thank you, Mitch. Have to learn how first.
I have Kodak Z990 and now have Windows 10. Struggling with how to load images onto the confuser and how to attach..
My old camera was a Kodak DX 6440 and used XP. Learnin' all over again..
Old 12-25-2015, 08:36 PM   #7
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Hey Larry, you do know that everything Mitch knows about Model A Fords, he learned from reading Grit. I can set you up with a subscription and give it to ya for half the price I sell to Mitch..........for sure.
"Bullshit and Brilliance Comes with Age and Experience"
"Hey Lady, ya wanna buy a Grit?"
"If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers
31 Model A is offline   Reply With Quote
Old 12-25-2015, 09:43 PM   #8
Larry Jenkins
I'm too young to read Grit.
