Does the flywheel with the multi plate clutch use a different starter motor,
I have a couple of engines with the multi plate clutch and see the starter is different to my 28 with a single plate clutch. The starter for the multi plate flywheel has a different size shaft and bendix. can I use the later starter motor on the multiple flywheel? Thanks Lawrie |
You can't use the stock later starter with the multiplate flywheel. You will need to use the Abell Drive or the Service Drive, both of which fit the 1/2" shaft.
This is pictured and talked about in the SERVICE BULLETINS. Also do a search here for "STARTER DRIVES", or "MULTIPLATE FLYWHEEL", etc. |
I looked this up here and there are tons of threads on this, you can not use the later starter with the 5/8 shaft with the early mulitplate flywheel, there isn't clearance enough for the 5/8 shaft/bendix to clear and the bolts will catch and make havoc with the flywheel. here are some links to the previous posts.
https://www.fordbarn.com/forum/showth...ywheel+starter https://www.fordbarn.com/forum/showth...tting+flywheel |
Thanks Guys, I was going to sell the early starters ,but will now keep them to go with the engines that have the multi plate flywheel.
Lawrie |
OOOOOPS !!! A while back I changed out a starter on a multi disc clutch car . The vehicle had been flooded and the original starter motor was full of water . Whilst I dried it out etc etc I replaced it .I without thinking I grabbed one out of the "stores" and put it in and it worked just fine ,out of about 10 starter motors I chose one with the 1/2" shaft . The starter motor fairy smiled on me !!! . I checked the ones I have and only one other 1/2" motor . I see the Bendix "gear" is 1/4" dia narrower than the 5/8" shaft so a regular could not engage the ring gear but I bet nasty expensive noises would have followed . "Familiarity breeds contempt" as we say ,I will be more carefull next time !!!
John in sunshine and showers Suffolk County England . |
#6 | |
Must have been more than just SHOWERS, to flood the starter ![]() After 5 years drought, it's finally RAINING HERE! GLAD MY CARRIAGE HOUSE IS UP HIGH! Your comments reminded me, Friend, Ron, put a rebuilt BOSCH starter on a VW-Bug, wouldn't start, it was a look-alike starter for some other application & it turned in the REVERSE DIRECTION ![]() Bill W.
