I recently purchased my second Model A (1928 Tudor) that has a Mallory ignition installed. It has a dual point system and seems to run quite well. The problem for me is I have no information on how to set timing or point gaps. Can someone point me in a direction that will lead to an understanding of the ignition system. I plan to pull the head this weekend and want to make sure I can properly set the ignition during reassembly.
Thanks for you help. Bob ![]() |
Contact "FS Ignition" & "FSignitions.com", they should be able to help you.
Bob
If you are going to put the same head back on, mark the distributor location to the head, when mated again you should be so close a timing light would not able to show any difference.
Steve - Santa Rosa |
This is what I use.
A new Mallory single point distributor is probably the best change you could make, for BETTER/MORE TROUBLE FREE driving. Makes it like a whole "new" car!
If you're confused with your old dual point distributor, just throw out one set of points & it'll run FINE! Just set your timing in the normal way. Bill W.
Jim P. central Ohio 1930 Tudor Sedan 15 grandchildren and 2 great grandchildren and loving it!! |
Contact Bubbas Speed shop Speedway Indiana
He does a great job with new Mallory Distributors |
Thanks for all of the input. I am not putting the same head back on but I think I have enough info to work through the process. I will report back when I install the new head.
Bob |
