Old 12-03-2015, 11:10 AM   #1
johnmi
Default Safety Wire Fly Wheel Housing
What is the proper route or direction of the wire to go around the four bolts . The holes in the bolts are not always in the right place. I have the safety wire pliers. Thanks John
johnmi is offline   Reply With Quote
Old 12-03-2015, 11:23 AM   #2
Bob C
Default Re: Safety Wire Fly Wheel Housing
You do it in the direction that will tighten the bolt.
Bob
Old 12-03-2015, 11:58 AM   #3
katy
katy's Avatar
All that you have to remember is that the wire always should pull the fastener in a tightening direction.
Old 12-03-2015, 02:21 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
My 4 bolts had a single wire run through each of the 4 bolts and the two ends twisted together. Some people have run two wires and run each through only 2 bolts. I believe the original way was how mine was done with one wire through the 4 bolts.
Old 12-03-2015, 07:32 PM   #5
1931 flamingo
1931 flamingo's Avatar
Doesn't matter, doesn't show........................
Paul
Old 12-03-2015, 07:53 PM   #6
53RYDER
Help a newbie out here please. So if the bolts retaining the flywheel (to whatever) are not secured with wire they will come loose or even off? I'm asking because I don't know.
Glenn
53RYDER is offline   Reply With Quote
Old 12-03-2015, 07:58 PM   #7
Patrick L.
Patrick L.'s Avatar
Glenn
Those bolts shouldn't come loose without the lacing wire, its just an extra measure that Henry thought was necessary for conditions of the day.
It probably doesn't make much difference how these bolts are laced, they really don't need to done to aviation standards. Its just if you're going to do it, might as well do it right.
Old 12-03-2015, 09:11 PM   #8
53RYDER
Thanks Patrick!
Glenn
Old 12-03-2015, 10:17 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Unless you're in for SHOW, use lockwashers & a dab of BLUE LOCTITE. Just "SET IT & FORGET IT"!--LOL
Bill Tight
"THE ASSISTANT GURU OF STUFF"
