This might be a dumb question but I don't seem to be able to stop water from leaking from the water outlet on to of the head. Yesterday I broke the outlet casting trying to tighten and upon removal the gasket seemed to be blown out on one side. Should I be using more than one gasket? also I see the vendors sell a copper gasket for show cars, although I'm building this as a daily driver, should I switch to that gasket over the paper ones? All help appreciated. Harv
Many people use no gasket, but make sure the outlet mounting surface is dead on flat, then use a bit of sealer on the mating surface.
Never use a paper gasket, as they get wet and squeeze out of place, and that's when you crack the casting. |
Thanks Tom, that's the route I'll go. Harv.
two ways to go no gasket with rtv or a copper gasket. paper is a no-no
surfaces need to be flat i have never had an issue using the copper gaskets I also use them on my cars cause it looks better Last edited by Mitch//pa; 11-28-2015 at 10:26 AM. |
Think I'll buy a copper gasket as a back up. Harv.
I've also never had a problem using a copper gasket, and use one on my car.
I think the paper gaskets are sold to increase sales of new water outlets. ![]() |
Tom, do you use gasket sealer with the copper gasket? Harv.
I'm not Tom but I don't and try to avoid it whenever possible
Thanks all, copper gasket it is. Harv.
I like the orange Permatex sealer with or without a thin gasket.
(There is no such thing as a dumb question) ![]() |
I've broken ears torqueing with thick copper gaskets but never with no gasket. I file flat and use a thin film of Permatex.
#13 |
This is what I use, without a gasket. Pretty hard to break this one if at all.
#14 |
Chief taught me how to cut gaskets, with a small ball pein hammer, with a tap-tap-tap-tap. Minerva sported a Bill, special, gasket, cut from a brown paper bag, a careful smear of BLACK RTV, on both sides, & NEVER broke the neck or LEAKED, so THERE! "Maybe" a good subject for "MYTH-BUSTERS"??
Bill W.
#15 |
#16 | |
![]() Quote:
Last edited by Y-Blockhead; 11-29-2015 at 03:50 PM. Reason: Add link... and correct spellin' |
#17 |
Thanks Y-Blockhead
#18 | ||
![]() Quote:
#19 | |
![]() Quote:
![]() ![]() Bill W.
#20 |
Just use RTV on my installs. Haven't cracked a neck since.
Oklahoma City Model A Restorers Group. |
