Old 10-25-2015, 07:24 PM   #1
1929
Default Aluminum Timing gear
is it very reliable to find the TDC using the timing pin on a Aluminum timing gear?
1929 is offline   Reply With Quote
Old 10-25-2015, 07:38 PM   #2
1955cj5
1955cj5's Avatar
Default Re: Aluminum Timing gear
If it was installed correctly it ought to be fine....however, on the aluminium gear that I bought the "dimple" was pretty small, I should have drilled it a little to make it easier to find....
Verify TDC visually by taking the #1 spark plug out and if the engine is timed look at the position of the rotor, ought to be pointing at about 5 O'clock or the #1 contact on the distributor housing...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 10-25-2015, 07:38 PM   #3
glenn in camino
glenn in camino's Avatar
I always drill the indent in the timing gear a little deeper, in fiber or aluminum timing gears.
Old 10-25-2015, 07:40 PM   #4
1929
I wish I drilled it too, to late now, unless I take things apart again.
Old 10-25-2015, 07:41 PM   #5
1929
I wish I did the same, it just does not feel right.
Old 10-25-2015, 07:42 PM   #6
1955cj5
1955cj5's Avatar
If you think you've found the dimple with the pin you could also use a mirror and flashlight to see the dimple through the timing hole....
I bought one of those aftermarket timing indicators for the front pulley but haven't installed it yet....
