I have a 1951 F1 with a 276 Flathead. I need a radiator. I see them from $179 to $850. 2 rows, 3 rows, 4 rows. I am in Florida, so heat is a factor. How much cooling do i need? How many rows? Aluminum or copper/brass? Who should i buy it from? Anyone have any experience with difference between brands and types of construction?
As always, many thanks to all.,...jack
Proud FNG We fixem cars. Heap Good! |
Have your original recored. Flat motors need all the cooling they can get, so get as many rows as it will hold. Always brass for any car you plan on keeping for a while, as aluminum tends to go south fairly rapidly. Also, nothing better than brass for cooling except copper and silver.
Alan |
I have a Walker that I had recored to 4-rows. I am running stock WP's and a Car-type 3-blade fan. The most I have ever seen the Temp gauge move, even in slow traffic in 100-deg weather, is about a needle width. Copper/brass is expensive now, but it's the best. Watch out on cheap aluminum rad's for tanks that are glued in place, no repairs possible.
'52 F-1, EAB flathead |
Did you mean the 226?
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
I believe he has a bored/stroked V8
Existing shroud is to be installed on new radiator.
