Old 09-26-2015, 03:09 PM   #1
roert
Default ratio and pinion
sorry my english i right with translation.
i have a 1936 coupe with 21 bolt engine.
i restord my car.
I would like to go a little faster.
would you give me 3.54:1 or 3.25:1 recommend. and much brings about in mph
thank Robert
roert is offline   Reply With Quote
Old 09-26-2015, 03:14 PM   #2
petehoovie
petehoovie's Avatar
Default Re: ratio and pinion
The smaller the gear ratio, less torque but higher speed. I'd go with the 3:54 to 1 of the two you mention. I think 3:78 to 1 is the best overall ratio.
Old 09-26-2015, 04:05 PM   #3
jimTN
3:78 unless you are running on absolute flat ground and not in city stop and go traffic. 3:78 will put you up to 70 mph or so with a 221 basically stock engine.
Old 09-26-2015, 04:53 PM   #4
johndee138
johndee138's Avatar
I will second the recommendation for the 3:78 gearing. Just did my 36 with it and am VERY happy. The stock gearing it came with (4:11) was fine for 1936 but not so satisfactory for 2015.
johndee138 is offline   Reply With Quote
Old 09-27-2015, 09:52 AM   #5
qmdv
qmdv's Avatar
I used to have a 29 rdst pickup with a B motor and a Cook four port head. 7.50x16 on the rear. I ran 3.27 to 1. It was great. Guess a B has more torque than a flat head.
Tim
qmdv is offline   Reply With Quote
Old 09-27-2015, 10:17 AM   #6
rotorwrench
rotorwrench's Avatar
Columbia overdrive would be better but 3.54:1 would get your top speed up a notch. It is harder for the engine to get it there though. The 3.78 is the best all around if you can't find the Columbia overdrive.
Old 09-27-2015, 11:21 AM   #7
VeryTangled
VeryTangled's Avatar
Hi Everyone, I had the same problem with my '36 with 21 stud engine. Original rear gear 4.11:1, top speed 55MPH. Replaced with 3.78:1, top speed over 70MPH.
I got a whole replacement rear end, supplied by CharlieNY here on the 'Barn. I've never personally had a rear apart and back together. I am very happy!
Using a translator:
Hallo allerseits , ich hatte das gleiche Problem mit meinem '36 mit 21 Bolzenmaschine . Original hinteren Gang 4,11 : 1, Höchstgeschwindigkeit 55 Stundenmeilen . 1 , Spitzengeschwindigkeit über 70 Stundenmeilen : mit 3,78 ersetzt.
Ich habe eine ganze Ersatz hinteren Ende durch CharlieNY auf der " Barn versorgt hier . Ich habe noch nie persönlich hatte eine Rück auseinander und wieder zusammen. Ich bin sehr glücklich!
-Jeff H
Old 09-27-2015, 11:28 AM   #8
Mr 42
Mr 42's Avatar
Have a friend here in Sweden running a 36 Convertible 21 stud original engine,
3,25 and its slow/hard to get running he don't like it and it takes quite a lot of fuel tom, probably because all the hard work it have to do.
så 3,54 or 3,78 will probably be the best.
Mr 42 is offline   Reply With Quote
Old 09-28-2015, 07:37 AM   #9
scooder
Very tangled,
If yours only went 55 mph with a 4.11, it was not running right. Should easily do 70 + mph.
3.78 is best.
Martin.
scooder is offline   Reply With Quote
Old 10-01-2015, 02:05 PM   #10
roert
thanks
Old 10-01-2015, 03:54 PM   #11
Bassman/NZ
Bassman/NZ's Avatar
Tim
a 29 r/p is a hell of a lot lighter than a 36 coupe.
Bassman/NZ is offline   Reply With Quote
Old 10-01-2015, 04:53 PM   #12
supereal
supereal's Avatar
If you need to drive at both city and hiway speeds, the best choice is an overdrive. Good Columbias are getting hard to find, and pricey, particularly for the early cars. I suggest you consider a Mitchell OD. I have an OD in my '47, and it gives the best of worlds: good power for starting out and hills, and comfortable cruising without over revving the engine. I have a 3:78 rear with a 30 percent reduction of engine speed when engaged.
supereal is offline   Reply With Quote
Old 10-01-2015, 09:34 PM   #13
qmdv
qmdv's Avatar
I am currently building a 32 highboy roadster. I have some 3.27 I was thinking of running with a 276 cu in flathead. should be OK. I think.
Tim
Old 10-02-2015, 07:28 AM   #14
scooder
Tim,
It depends on what "drive" your after. I wouldn't go to 3.54, let alone 3.27! Do you want a hot rod or q highway loafer?
Martin.
Old 10-04-2015, 01:25 PM   #15
roert
36 coupe
i think 3,78 is the best for me
thanks
Old 10-04-2015, 01:46 PM   #16
35fordtn
35fordtn's Avatar
If you have a original 1935-36 rearend you will have a hard time finding the correct 10 spline 3.54's. On my sedan I had to convert the driveshaft from 10 to 6 spline
Old 10-05-2015, 09:08 AM   #17
JSeery
JSeery's Avatar
Originally Posted by scooder View Post
Tim,
Martin.
Like Martin's comments, LOL. I prefer the 4.11 gears myself, but if you want higher gearing I wouldn't go above 3.78. I know a lot of people do, but unless you are driving on the highway all day long I don't know why you would want to. As others have stated if that is really the objective I would go with an overdrive, best of both worlds.
Old 10-05-2015, 07:26 PM   #18
Talkwrench
Talkwrench's Avatar
Not sure how much heavier a coupe is over a pickup but my little '37 21 stud turns over ok . 28 gearset, 3.78 rear and 7.50x16 tyres. in traffic every day no problems, don't even change out of top for some corners..
