Old 09-17-2015, 01:51 PM   #1
Ron in Quincy
Ron in Quincy's Avatar
Default Adapter for Model B Carbs ?
Some time ago someone posted that a Dealer had a adapter available that permits the gas line connection to face out like the Zenith and Holley Carbs.
Who is the Dealer that has these Adapters ?
Thanks, Ron
The reason I asked the Question, I have a B Top that has only threads and no seat; I was told that Zenith actually produced this Top as the 32 B had no gas filter between the gas tank and the carb and it was designed to use a 31 Side Bowl as the filter; I actually mounted a 31 Side Bowl on this top and the threads were correct and the inlet of the Side Bowl faced out. I do not plan on using this B Carb, just want to finish it as it will be For Sale and I do not want to run up the price by adding a 31 Side Bowl.
Has anyone else run into a B top like this ?
Last edited by Ron in Quincy; 09-17-2015 at 09:13 PM. Reason: Additional information
Ron in Quincy is offline   Reply With Quote
