Old 08-30-2015, 01:54 PM   #1
Beater
Beater's Avatar
Default aftermarket dist
ok guys here we go .
anyone know or used one of these?
http://www.ebay.com/itm/Model-A-Ford...-/151794714957
I cant get ahold of the guy yet, my main concern is what is it made out of, and where parts are available. im sure somebody has some info and or has used one here I hope
Beater is offline   Reply With Quote
Old 08-30-2015, 02:03 PM   #2
Benson
Default Re: aftermarket dist
Available brand new directly from Mel Mallory for around $300 ...
Company name is First Street Ignitions Inc. Well known
http://www.fsignitions.com/FSI_PRODUCTS.html
This might be Mel's ad as seller is located in Ponca City, OK ... same as Mel's business.
Most vendors carry them also ...
Old 08-30-2015, 02:13 PM   #3
Beater
Beater's Avatar
that's the city the ph number goes to so it must be him. thanks
Old 08-30-2015, 03:12 PM   #4
mrtexas
mrtexas's Avatar
They work great. I used to run one. The mechanical advance has been redone for Model A. I also like the electronic ignition.
mrtexas is offline   Reply With Quote
Old 08-30-2015, 05:48 PM   #5
duke36
I run the FS Zipper distrib. auto advance system; very good customer support if needed.
Old 08-30-2015, 07:41 PM   #6
glenn in camino
glenn in camino's Avatar
I gave up on my electronic distributor several months ago and went back to the stock setup. It now runs better than ever.
Old 08-30-2015, 10:32 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
They do seem to be hit and miss don't they? Some here have had and continue to have great results and others, not so much.
We have a guy in the club that had the zipper and no matter what we could not get it to run right, calls to FS and everything. We went to a stock system just to see if there was anything else that could be wrong and once we did the owner left it that way.
Old 08-31-2015, 12:14 AM   #8
hardtimes
hardtimes's Avatar
This IS good equipment ! I've run one of their electronic units for years and have never missed a beat. You must install precisely to their advice/instructions, for their electronic equipment. Runs good from idle right up thru the highest rpm that I've run. Of course, Bubbas special A/B distributor runs just as well. An old Mallory V8 set up right for 4 cyl A/B also performs very well ! Choice is good,eh
Old 08-31-2015, 12:29 AM   #9
Beater
Beater's Avatar
thanks for the info guys
Old 08-31-2015, 08:26 AM   #10
barkleydave
barkleydave's Avatar
Running a F.S. in stock dist. 1500 miles runs great.
1.Use new on off ignition key switch.
Rainmaker wired direct to battery with fuse.
Provides very clean DC current to coil and ignitor
barkleydave is offline   Reply With Quote
