Old 08-28-2015, 06:02 PM   #1
mrtexas
mrtexas's Avatar
Default STP in transmission oil
I'd like to buy some 680 viscosity oil(thicker than 600w or SAE 140) for easy shifting but don't want to buy 5 gallons.
Anyone adding STP to transmission oil to thicken it?
Anyone willing to sell me 680 viscosity oil enough for two transmissions?
mrtexas is offline   Reply With Quote
Old 08-28-2015, 06:07 PM   #2
Pete
Default Re: STP in transmission oil
How about adding corn starch to some SAE 140?
It works with cake batter.
Or how about talking one of your ex co-workers out of some.
Old 08-28-2015, 07:02 PM   #3
d.
Roger Kauffman, late MARC technical editor, said he used straight 100% STP in his transmission, steering box and rear end for 100,000 plus miles and stated that the fluid looked like the day he put it in, with no problems over many miles of cross country driving.
Reference his articles in the MARC NEWS.
It worked well for him with many road miles.
d. is offline   Reply With Quote
Old 08-28-2015, 07:44 PM   #4
Gil Sissons
Steve Mitchell....(Mitchell Overdrive) advised me this week 25%
Gil Sissons is offline   Reply With Quote
Old 08-28-2015, 07:51 PM   #5
duke36
I purchased Lubriplate SPO 288 gear oil by the gallon many years ago. It's about 250 SAE,very thick. and the closest I found to the actual 600w. Bearing supplies companies may sell it or Google for a distributor. It's still listed on the Lubriplate web site as available.
Old 08-28-2015, 10:12 PM   #6
Ron in Quincy
Ron in Quincy's Avatar
I have used straight STP in my transmissions for years and have had no problems. The turning cluster gear continually picks up the STP and distributes it upward to all gears. Sure makes shifting easier.
I also use 50 percent STP in the differential. The ring gear continually pick up the STP and distributes it to the top of the differential keeping spider gears, pinion, etc. well lubed.
Ron
Ron in Quincy is offline   Reply With Quote
Old 08-28-2015, 10:18 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
A bunch of people have done it and many have just bought what the vendors sell.
I have never read of a problem caused by using STP.
Old 08-28-2015, 10:24 PM   #8
Mike V. Florida
Mobil 600W super is rated ISO460 and the regular is something like 375. Why do you feel you need 680?
Old 08-29-2015, 07:11 AM   #9
Redbird
Redbird's Avatar
Get the 600w from berts.
Redbird is offline   Reply With Quote
Old 08-29-2015, 08:13 AM   #10
mrtexas
mrtexas's Avatar
In the past I bought 5 gallons of 460 and 680. A local wholesaler sold most of the oil for me. The 680 made shifting very easy in the summer. It was too stiff in the winter however. What I have in there now requires the idle to be very low to avoid grinding 1st gear.
Old 08-29-2015, 08:16 AM   #11
Mitch//pa
what do you have in there now?
Old 08-29-2015, 08:19 AM   #12
jerry shook
I add 8 0z of slick 50 along with 600w to all my manual transmissions and rear end it keep them cooler because of less friction. trans shift much smoother.
jerry shook is offline   Reply With Quote
Old 08-29-2015, 08:24 AM   #13
Tim B.
What about the clutch rod? Do you have it adjusted enough to accually push the throwout bearing far enough to release the disc? It may need adjustment. Just a thought. Tim
Tim B. is offline   Reply With Quote
Old 08-29-2015, 05:57 PM   #14
johnmi
What specific kind of STP are you guys using in your transmission Thanks John
johnmi is offline   Reply With Quote
Old 08-29-2015, 07:33 PM   #15
J Witt
J Witt's Avatar
Racers used to call it Synthetic Total Performance. ;-)
http://www.stp.com/products/multipur...FVU6gQodK_YCtQ
John
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
Old 08-30-2015, 07:22 AM   #16
Dollar Bill
Dollar Bill's Avatar
"What specific kind of STP are you guys using in your transmission Thanks John"
Click here: STP
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 08-30-2015, 07:57 AM   #17
Terry, NJ
Terry, NJ's Avatar
While I like STP for it's positive propertys, don't think of it as a magic bullet! It works fine in a Mod.A but not in some other transmissions. Maybe it's the ones with "Yellow metal" bearings, I don't know. However, I wrecked a Ford/Mazda 5 spd in my 88 E-150 with it. So it must be used sparingly. The Ford/Mazda box uses ATF (??) like some Chrysler standards did back in the seventies. I wouldn't advise putting it in a modern gearbox.
Terry
Old 08-30-2015, 09:59 AM   #18
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
STP in a synchronized trans, is TOO SCHLICKERY & CAUSES THE SYNCHROS NOT TO BE ABLE TO DO THEIR THING.
Bill W.
"THE ASSISTANT GURU OF STUFF"
