Old 08-14-2015, 05:42 PM   #1
91A-77B
Default Cad/LaSalle Trans to flathead
Anyone have the adapter and/or info for my early-50s modified 37 trans with Olds tailshaft to flathead? I want to insert it into '40 chassis, without butchering chassis, but obviously converting to open drive. I also have 37 stock floorshift which I'd like to consider same swap, but with torque tube conversion. I have access to machine shop with shaft-shortening/resplining capabilities. Any old timers out there?
91A-77B is offline   Reply With Quote
Old 08-14-2015, 05:54 PM   #2
Mike in AZ
Mike in AZ's Avatar
Default Re: Cad/LaSalle Trans to flathead
maybe Wil-Cap?...Mike
Mike in AZ is offline   Reply With Quote
Old 08-14-2015, 06:10 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
There are a few guys over on the HAMB that speak "Cad/LaSalle" stuff. Click the link below for quite a few HAMB threads related to C/L topics. DD
http://www.jalopyjournal.com/forum/s...&o=relevance&c[node]=5
Click Links Below __
T5 W/TORQUE TUBE
Old 08-15-2015, 06:08 AM   #4
91A-77B
Thanks, V8COOPMAN This will help me get on my way. Any others with info will be appreciated.
Old 08-15-2015, 09:35 AM   #5
41PICUP
41PICUP's Avatar
Try Wil-Cap, if anyone has one, they will have !
41PICUP is offline   Reply With Quote
Old 08-17-2015, 02:45 PM   #6
alchemy
alchemy's Avatar
I have an old aluminum bellhousing that adapts a Cad trans to a flathead. I don't remember the brand, but I think it's an Offy. It's not for sale, cause then what would I do with all the Cad transmissions I have?
The Cad transmission/adapter combo will be longer than the Ford. You may need to "butcher" the frame. Do a bunch of measuring before you get too far into it.
If doing the open shaft version you obviously don't need to worry about the length of the torquetube, but I'd bet you will need to remove the transmission mount crossmember, and possibly cut some of the top from the center crossmember cradle. And you will need to add some bracketry for the new rear axle mounting locators.
If you go with the closed drive version you will need to shorten the torquetube an approximate inch or two. Will require moving the transmission mounting crossmember back a bit. Might have enough clearance so you don't need to hack up the center crossmember cradle though.
alchemy is offline   Reply With Quote
