Old 08-10-2015, 03:33 PM   #1
papanomad
papanomad's Avatar
Default oil pan id
what did this oil pan come from?
papanomad is offline   Reply With Quote
Old 08-10-2015, 03:40 PM   #2
jimTN
Default Re: oil pan id
Ford trk or car with 10 or 11" clutch after 34. The big pressure plate and clutch come out without having to pull the pan. Of course you have to pull the enjine or trans first.
Old 08-10-2015, 05:39 PM   #3
26 lakes
Your pan is Canadian Military Truck. I have one just like it.
26 lakes is offline   Reply With Quote
Old 08-10-2015, 06:41 PM   #4
deuce_roadster
deuce_roadster's Avatar
I am curious about what makes it Canadian vs US truck.
Old 08-10-2015, 07:02 PM   #5
38bill
38bill's Avatar
I have a truck pan and it doesnt have that large clean out but the oil drain is the same. Makes working on the clutch much easier.
38bill is offline   Reply With Quote
Old 08-10-2015, 07:09 PM   #6
flatheadfan
flatheadfan's Avatar
I also have one (Canadian truck, C69T-6675). I don't think any American pre-'49 pans had an 11 inch removal cover and a clean-out.
Tom
flatheadfan is offline   Reply With Quote
Old 08-10-2015, 09:06 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
I have one similar, but w/o the clean out. I have never seen a two piece truck oil pan with a clean out like that, nor the round hole in the gasket area for the ventilation system.
John
Old 08-10-2015, 09:14 PM   #8
papanomad
papanomad's Avatar
thanks for info. I had this in back of garage and was going to use in an a-v8 project and wasn't sure where it came from.
Old 08-11-2015, 04:12 AM   #9
flatheadfan
Old 08-11-2015, 08:13 PM   #10
papanomad
papanomad's Avatar
are gaskets available for cleanout plate? or is it do it yourself?
Old 08-11-2015, 10:36 PM   #11
26 lakes
I am going to make my own. I bet there are not to many of these oil pans out there. The clean out is different than the F1 style pan.
Old 08-12-2015, 09:07 AM   #12
Bruce Lancaster
From the photos of the pan in post one, it looks like the vent is extended downward about 3 inches from the normal bump, presumably to extend past some chassis obstruction to reach moving air. I think, no guarantees on that, that the draft setup makes it pre-1943, as after that they got PCV to take care of ventilation thoroughly.
