going to put gas tank behind seat,carb is original zenith,getting ready to buy electric pump,found 1 preasure is 1 to 3 psi,will this work and running 12 volt
That should work fine.
I'm running a 12 volt Holley on a 6 volt battery, and I still need to use a resistor to slow the pump down to get the pressure lower. |
The question is what is the maximum pressure a Zenith float valve will seal against.
Stock the A would see a gravity feed, thus the pressure with a full tank would be the height times the density of gas. The stock setup never delivered over 0.6 psi, even with a full tank. OK, so how much pressure to shut the float valve at 0.6, 1.0, 3.0 psi? Not all valves have exactly the same size hole, I have some that are ~3/32” and a few that are 1/8” with a ball. Let’s use the larger size. The surface area of a 1/8” opening ( 0.012 sq” ) times the pressure = force needed. Converting psi to g/sq” you get 3.3g for 0.6 psi fuel, 5.4g for 1psi, and 16.3g for 3psi. Yea, I know grams are mass, not weight or force but we are all stuck on the surface of earth with it’s 9.8 M/Ssq., so that many grams levered upward will close the valve. Now, The float does not act directly, it acts through a lever with unequal length legs. Guessing ![]() Looking at it percentage wise, 1psi is a 67% increase over a full stock tank with gravity feed, 3psi is a 500% increase. When Ford went to the B carb with a pump a helper spring was added to the float. So, the answer is I don’t know, but I would avoid anything much over 1 psi. Another consideration is that the fuel bowl height (amount the float is submersed) will increase as more float valve pressure is needed as the fuel pressure goes up. Expect the carb to need the float level reset. |
Way to go Mike. You just smoked my last brain cell.
![]() They don't like to run in overdrive so early in the morning. ![]() ![]() BTW, he could also run a recycling line back to the tank to lower the pressure, plus it would keep the fuel cooler to avoid vapor lock from crap gas. ![]() |
confusing,reg that i have looked at has a range 1 to5 2to 6 ect, i did see 1 awhile back on a car had a dial i think 1 to 5 maybe dependent on fuel pump preasure,so i am looking at 1 max,and not having test equipment to know for sure,and auto parts store for fuel injection only, they hardly know what a carb is
