Old 07-13-2015, 11:27 PM   #1
Ed Wendell
Ed Wendell's Avatar
Default Trimming a Repo Steering Wheel
Just purchased a repo steering wheel and all of the USA made ones require some trimming of the mold seam.
Anybody done this? Thoughts, suggestions on the best way.
Thanks,
Ed
Ed Wendell is offline   Reply With Quote
Old 07-14-2015, 12:11 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Trimming a Repo Steering Wheel
Sharp hobby knife and sand paper.
Old 07-14-2015, 04:41 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
A potato peeler worked well for me, pretty good control, so it didn't "dig" in, & it did the tight curves well.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-14-2015, 05:40 AM   #4
JOHN CT
JOHN CT's Avatar
I received my in shock I had to remove extra mold and sand . I followed the instructions removing extra with razor and using 1200 grit paper it turn out great
JOHN CT is offline   Reply With Quote
Old 07-14-2015, 06:36 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I've done it the same way. It's an easy job and goes quickly.
Old 07-14-2015, 06:41 AM   #6
Mitch//pa
Bill W.
Now that's thinking outside the box... Dad hand whittled me this monkey out of a peach pit
Old 07-14-2015, 06:48 AM   #7
mlp623
mlp623's Avatar
In addition to the trimming with a sharp razor - wet sanding was key for me. 600 and 1200. The outer part is easy - but use caution when cutting in where the "spokes" meet the wheel - they were a little tricky.
mlp623 is offline   Reply With Quote
Old 07-14-2015, 06:56 AM   #8
Pat Martone
Pat Martone's Avatar
I also finished with the wet sanding with 1200 grit, but with the steering wheel "mounted" on the column and placing towels around the column and car floor. It came out great and there is no remaining evidence of any seams. It took a few hours to completely "finish" the wheel.
Pat Martone is offline   Reply With Quote
Old 07-14-2015, 07:05 AM   #9
Tom Wesenberg
Good point about the inside curves.
A razor blade doesn't work well there, and I think I used a rat tail file to do the sharp inside curves, then sandpaper.
Old 07-14-2015, 07:15 AM   #10
C26Pinelake
We should expect to trim an offshore repro part but not American made! I would expect a higher standard of workmanship! Wayne
C26Pinelake is offline   Reply With Quote
Old 07-14-2015, 07:29 AM   #11
mlp623
mlp623's Avatar
Ah, right. I did use a file in a few places, including the inside curves, and it worked well.
Old 07-14-2015, 08:35 AM   #12
BILL WILLIAMSON
BUT, I "lied"--Ted really carved it, he took a class & also carved a HILLBILLY & a '32 ROADSTER, his teacher didn't know HOW to do a MODEL A!
BUT, I REALLY do know how to do stained glass!
Dad
Old 07-16-2015, 09:08 PM   #13
Ed Wendell
Ed Wendell's Avatar
Thanks to all for your great information. I am trying Bill W's potato peeler idea and it seems to be working great.
Thanks again.
Ed
