Old 07-11-2015, 06:58 PM   #1
tubman
tubman's Avatar
Default Pilot Bearing or Bushing
I'm still trying to track down the "rattling" noise in my '51 club coupe. Anyone know if it has a pilot (ball) brearing or a pilot bushing? If it makes any difference, the car is a late build, delivered to the original owner on July 3, 1951.
Old 07-11-2015, 07:42 PM   #2
WestCoast
Default Re: Pilot Bearing or Bushing
it has a bushing, and a worn bushing doesn't usually cause a rattle, just clutch chatter, or a real bad vibiation because the clutch can get off to one side of the flywheel and cause an imbalance on the rotating mass
WestCoast is offline   Reply With Quote
Old 07-11-2015, 08:32 PM   #3
tubman
tubman's Avatar
That's what I expected, but it doesn't make me very happy.
I think it may be wrist pins?
Old 07-11-2015, 09:09 PM   #4
Mike in AZ
Mike in AZ's Avatar
throw out bearing?.. Mike
Mike in AZ is offline   Reply With Quote
Old 07-11-2015, 09:30 PM   #5
Ross F-1
Ross F-1's Avatar
I'd kind of be surprised if the clutch is original. It could have had a ball bearing replacement for the pilot.
I don't recall, did you try running it with no belts?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 07-11-2015, 11:00 PM   #6
tubman
tubman's Avatar
Ross,
Yes I did and the noise is still there. It goes away if I let the clutch out in high with the car not moving, Also, I can't hear it on the road in high, though it might be obscured by road noise.
BTW, I'll be at the EFV8CA meet in Brainerd next week (weather permitting), and I welcome anyone who wants to listen and give their opinion. (It's only 20 miles from home for me, and since it's not gotten any worse over the last couple of years, I'm going to run down there.)
Old 07-12-2015, 09:34 AM   #7
earlyride
earlyride's Avatar
I had a similar rattle on my 8ba style merc and it went away when I loosened the two bolts that holds an aluminum cover plate in back of the oil pan, don't know why though. John
earlyride is offline   Reply With Quote
Old 07-12-2015, 09:43 AM   #8
tubman
tubman's Avatar
Wow! You'd think it would work the other way (tighten them to make the noise go away). I'll have to think about thia one; maybe look at one of my spare engines so I can see exactly what you are refering to.
