Old 06-27-2015, 10:09 AM   #1
sethkestenbaum
sethkestenbaum's Avatar
Default transmission install: Felt Universal Joint Seal
Should one trim the felt band that goes in the groves on the upper and lower Universal Joint Housing Caps? The ones I have seem a little long and are keeping the caps from pairing up flush.
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
Old 06-27-2015, 11:11 AM   #2
Mitch//pa
Default Re: transmission install: Felt Universal Joint Seal
i am usually able to slowly tighten and compress them together without cutting...
Old 06-27-2015, 01:21 PM   #3
sethkestenbaum
I used a flat head screw driver to compress the felt into the groove. It worked thereafter.
Seth Kestenbaum
