Old 06-10-2015, 11:10 AM   #1
teedog
teedog's Avatar
Default New aries muffler
Has any one had a problem with installing an original muffler pipe clamp on the aries muffler ? Mine seems way too tight. Muffler pipe diameter is a little bigger than the one i took off that i bought 40 years ago. Im talking about the frame clamp. Thanks
teedog is offline   Reply With Quote
Old 06-10-2015, 11:21 AM   #2
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default Re: New aries muffler
I used a new clamp sold by Snyder's and didn't tighten it too much. There must be a little looseness on the tailpipe as the pipe has to expand and contract due to the heat. The pipe is liable to crack at the weld behind the muffler if it's clamped too tightly.
Barry B./ Ma. is offline   Reply With Quote
Old 06-10-2015, 11:39 AM   #3
teedog
teedog's Avatar
I took a measurement with dial calipers, new pipe 1.786, old 1.768 about .020 bigger
Old 06-10-2015, 11:57 AM   #4
msmaron
msmaron's Avatar
Does this help you
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 06-10-2015, 01:00 PM   #5
teedog
teedog's Avatar
my old muffler looks like the one on the left, i am talking about tail pipe diameter where clamp to frame slides up. thanks for the drawing. mine is also a 1930
Old 06-10-2015, 01:10 PM   #6
mlp623
mlp623's Avatar
There are 2 frame clamps depending on year. May be worth the 6.50 for the one from Aries... http://www.amuffler.com/content/otherproducts.htm
mlp623 is offline   Reply With Quote
Old 06-10-2015, 02:36 PM   #7
teedog
teedog's Avatar
might be the answer, thanks
Old 06-10-2015, 02:59 PM   #8
30aadoodlebug
30aadoodlebug's Avatar
I bought an aries from tams a few months ago at a flee market. They are weird, but I loosend the rear clamp a bit and ran it for a while and its fine now. Just my two cents; m I also have a 30.
30aadoodlebug is offline   Reply With Quote
Old 06-10-2015, 08:32 PM   #9
redmodelt
redmodelt's Avatar
I would 2ed the get the proper clamp from Aries. They are the proper size and made for that brand. I only quickly saw the one that was put on the car we have in the shop. They have a lining in them.
Old 06-10-2015, 08:41 PM   #10
SteveB31
SteveB31's Avatar
First thing to realize about this clamp, is that their are currently 8 rear tailpipe clamps being made. We do not know which one you have. If it has a square hole and a carriage bolt, then it is a cheap Chinese one. Throw it away. Buy a good one that uses a bolt with a castle nut and cotter pin, as you do NOT want it tight. The tailpipe /muffler assembly grows by roughly an inch when it gets warm, and must slide in that rear bracket or it will bend at the front and leak.
Steve Becker
Berts Model A Center
SteveB31 is offline   Reply With Quote
Old 06-11-2015, 07:58 AM   #11
teedog
teedog's Avatar
it is an original clamp, it has been on for the 50 yrs i have had it
