Old 05-21-2015, 04:09 PM   #1
Tod
Default New Thomas head script
For those of you that would consider buying a "Thomas" 7:1 aluminum head from Snyder, how adamant are you that it has the "Thomas" script on it?
My new one is ready to cut, but I would like a survey of how many people care about the script.
Tod
Tod is offline   Reply With Quote
Old 05-21-2015, 04:30 PM   #2
Vicky
Vicky's Avatar
Default Re: New Thomas head script
Tod,
Our Speedster has an original Thomas Head, Side Cover and intake, all with the Thomas Script. If I was buying a Thomas head to replace this one, I would prefer the Thomas Script to match the other components.
If I was buying one for performance on any other engine, it would not make any difference if it had the script or not.
Bob
Vicky is offline   Reply With Quote
Old 05-21-2015, 04:52 PM   #3
Tod
Originally Posted by Vicky View Post
Tod,
Bob
Maybe it would just be best to plan for it.
Tod
Old 05-21-2015, 06:04 PM   #4
Logan
Logan's Avatar
I think it should be on there. How else would it be identified as a "thomas" head rather than just some random high comp head.
Cowtown A's
Logan is offline   Reply With Quote
Old 05-21-2015, 11:03 PM   #5
Tod
Originally Posted by forever4 View Post
What about the "Tod" script?
I thought about putting my company name, "Rev C", on it. But people tend to like proven/traditional names.
Tod
Old 05-21-2015, 11:14 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
If you are spending the time to reproduce the head, I would think the Thomas script would be important.
Does it effect the cost/reject rate?
Old 05-22-2015, 01:53 AM   #7
M2M
M2M's Avatar
If I was in the market for such a head I'd want with script.
M2M is offline   Reply With Quote
Old 05-22-2015, 04:43 AM   #8
ronn
I'ld also prefer the script-no doubt.
Old 05-22-2015, 05:12 AM   #9
Juggler
Juggler's Avatar
Tod
Exactly. If it's a homage copy of a period piece then most customers will it want to look like the original, including the script.
If you come up with a new head, particularly an improved combustion chamber design, some of which have been suggested on previous threads, then by all means put your own name on it.
Cheers
Juggs
Juggler is offline   Reply With Quote
Old 05-22-2015, 11:27 AM   #10
26Tguy
26Tguy's Avatar
I would also want the script.
Tod, are you doing another run for them or redesigning it or ??? Please tell
26Tguy is offline   Reply With Quote
Old 05-22-2015, 02:13 PM   #11
Tod
I modeled up the script to cut it on the new pattern. I will leave it as is.
26Tguy, this is a new pattern. The old pattern had issues that led to casting problems as well as machining difficulties. Patterns should be left to patternmakers.
Tod
Old 05-23-2015, 03:24 PM   #12
Tod
The Thomas script is in place. I can make an Excel picture of it for posting, if someone can post it for me.
Tod
Old 05-23-2015, 03:36 PM   #13
Juggler
Juggler's Avatar
I'll do it Tod - you've got my email
Old 05-23-2015, 04:41 PM   #14
redmodelt
redmodelt's Avatar
You might think about casting the compression ratio and maybe your name so there is no confusion later. Even if it carries a different scrip from the original not everyone will know and may think at a later date that they are buying an original.
Old 05-23-2015, 05:26 PM   #15
Tod
OK. As soon as I can.
Tod
Old 05-23-2015, 05:28 PM   #16
Tod
Mine will not be confused with the original.
Tod
Old 05-23-2015, 07:31 PM   #17
bgarrett
bgarrett's Avatar
Must. Have. Script.
bgarrett is offline   Reply With Quote
Old 05-24-2015, 02:44 AM   #18
MikeK
MikeK's Avatar
One way to remove the script from green sand.
MikeK is offline   Reply With Quote
Old 05-24-2015, 03:28 AM   #19
C26Pinelake
I totally agree !
Wayne
C26Pinelake is offline   Reply With Quote
Old 05-24-2015, 08:42 AM   #20
Tod
I sent an Excel rendering of one view of my Thomas head to Juggler for posting in this thread.
The noticeable points of difference will be 1) a correct water-neck mating surface, and 2) a correct water pump mounting surface/size. Also corrected are draft areas on the water pump end and correct draft in the spark plug holes so that molds are not breaking on every head from now on. Adequate draft is actually put on the outside of the head also. This will allow the foundry to make a nicer looking casting.
But these are not the main reasons I am re-making this. The current parts are passable, but when it comes to machining them, the pattern is bad enough to make it not worth my time to struggle through the difficulties caused by poor pattern design and poor foundry fixes to the problems.
Tod
