I use your method for adjusting the front brakes ( it is quite easy to remove the pin from the brake rod clevice) but I can't remove the pin from the rear clevice rods. I am on my back like a contortionist and I just can't remove the pin. Is there a simpler way - is a lift necessary?
I must be doing something wrong and your advice would be appreciated. |
what about removing it off the service brake shaft? thats where the adjustment is also
for stubborn pins i use a side cutters / dykes to get under the pin head and pry out Last edited by Mitch//pa; 05-20-2015 at 08:08 PM. |
