I have a 32 Ford with Original headlamps. The headlites have the new Drake reflectors and bulbs. The lights are great!
Here's my issue: I took the car to a shop that has the old style headlite adjusting equipment, but he couldn't get the things to adjust using it. So, I'll try the old method of a wall at some distance and height. Does anyone have the correct original distance and height that Ford used? I've got an area that's level that I can use. Any help appreciated Thanks Jim |
Hi Kahuna, The information you require is printed in detail in the owners handbook for your car. Regards, Kevin.
Thanks Koates
I'll try to find one Regards Jim |
Firs you start with focus -- look at this link-- http://www.abarnyard.com/workshop/lamp_focus-2.htm
here is a link to adjustment--it's model a but functionally the ame as 32 http://www.abarnyard.com/workshop/focus-2a.htm bright lights with bad focus are just bright lights to look at them but not bright down the road where you need it |
Hi Kurt
Thanks for the diagram link Regards Jim |
Looks like I need to call Willie to get some supervision on site. |
#7 | |
![]() Quote:
Head Lights on my 80 year old car are like the brakes and wipers, theoretical. Tail lights are lovin' life and work very brightly. Of course nobody can see my turn signals (my arm) at night either!
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
I enjoy driving the A at night, can see good, even with original charging system i drive without worries even though I have quartz halogen bulbs ---they work better than seal beams
