Old 04-21-2015, 12:15 PM   #1
tls3028
Default Driveline ID question
Just got ahold of a 40 convertible w/ a 51 merc EAB head engine with 5/8" belts and 4 blade fan. Thus not real sure of what the engine is. Has the left rear oil filter canister. My main question today is transmission oriented. Will the trans and rear end be changed due to the later model engine being utilized? I read where the bellhousing is no longer attached on the 49-53 flatheads. I am needing to order some transmission parts. New 2nd syncro and other misc. Some input would be nice.
tls3028 is offline   Reply With Quote
Old 04-21-2015, 12:19 PM   #2
flatjack9
flatjack9's Avatar
Default Re: Driveline ID question
The original transmission can be used with that engine using the 1/2 bellhousing used with Mercs and trucks.
Old 04-21-2015, 12:27 PM   #3
V8 Bob
V8 Bob's Avatar
The original transmission and rear can be retained if a '48-'52 truck/'49-'50 Merc 1/2 bell was used to mate the late engine to early round pattern transmissions. A picture or two of the engine/trans taken under the car will show any changes that were done.
