Old 04-19-2015, 02:47 PM   #1
benp
Default noise in drive shaft
How does one rebuild a 1948 Tudor drive shaft. Have a grinding noise in the center of the shaft. Speedway has a conversion kit to install a drive shaft but I am not sure this is the way to go. Any help appreciated.
benp is offline   Reply With Quote
Old 04-19-2015, 03:14 PM   #2
G.M.
Default Re: noise in drive shaft
Contact [email protected] He makes a replacement center bearing. Ask
for his removal and installation instructions. G.M.
www.fordcollector.com
Old 04-19-2015, 11:04 PM   #3
Drbrown
Drbrown's Avatar
Should have a grease fitting there. Bunch of threads here on this work including Old Henry's personal experience.
Drbrown is offline   Reply With Quote
Old 04-20-2015, 05:17 PM   #4
benp
@G.M. Thank you so Much this is a Huge prize link. Skip also does coils and water pump, and center support bearings thanks.
