Old 04-16-2015, 08:55 PM   #1
moonshine runner
moonshine runner's Avatar
Default Power steering syetem
Hello all,
Have a question please. Does anyone know if the power steering system from a 56 Merc is the same as the 56 Victoria?
If so, I may have a chance at buying one. Thanks in advance!
Kevin
"Failure is simply the opportunity to begin again, this time more intelligently".
Henry Ford.
moonshine runner is offline   Reply With Quote
Old 04-16-2015, 09:48 PM   #2
scicala
scicala's Avatar
Default Re: Power steering syetem
I would assume it's interchangeable but can't say for 100% sure though. I know the suspension parts are all the same, like the control arms, spindles, ball joints, tie rod ends, etc. Frame looks the same too.
Sal
scicala is offline   Reply With Quote
Old 04-17-2015, 08:36 AM   #3
Ole Don
Ole Don's Avatar
Go get it, parts in hand are worth a lot more than ideas and wishes.
Ole Don is offline   Reply With Quote
Old 04-17-2015, 08:29 PM   #4
moonshine runner
Sal
Thanks Sal!
Kevin
Henry Ford.
Old 04-17-2015, 08:29 PM   #5
moonshine runner
Thanks Don,
That's kinda what I am thinking too!
Kevin
Henry Ford.
Old 04-18-2015, 09:38 AM   #6
Ole Don
Ole Don's Avatar
Take big sockets when you go, the crankshaft bolt needs to come out to get the front pulley off. When you put on the part on the right frame rail, you don't need the factory special nuts. Two bolts welded to the bottom of the frame while the part is bolted with the two long bolts to locate, works fine and is easy to do.
