Old 04-13-2015, 08:14 PM   #1
GT66PONY
Default Whitch one do I use ??
I have a roll of after market frame welting that is 2 inches wide and made of nylon. and I have a roll of belting that is 1.5 inches wide Made of reinforced rubber! Both are about the same thickness.
Which would be better to use?
GT66PONY is offline   Reply With Quote
Old 04-13-2015, 08:21 PM   #2
Mitch//pa
Default Re: Whitch one do I use ??
i would'nt use either
Old 04-13-2015, 08:30 PM   #3
GT66PONY
OK, Why, What would you use?
Old 04-13-2015, 08:36 PM   #4
Mitch//pa
this is the proper size and material available which mimics what was originally used closer than rubber or a wider width nylon. and it costs 16.50 to do the whole frame
Old 04-13-2015, 09:43 PM   #5
J Franklin
J Franklin's Avatar
Your nylon belting might be of interest to someone rebuilding Gabrial or Watson snubbers.
Old 04-13-2015, 10:58 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
I use what mitch posted on the 30 AA I did years ago. I found you should cut the roll in half and tape each half to the frame rails, then let it set for a day or two to normalize, then mark and punch the holes. I unrolled the welt and taped and punched the holes in an hour, but when I went to bolt parts on a couple days later I found the stuff had to be pulled hard to get the holes lined up again. It shrunk a bit.
Old 04-14-2015, 05:44 AM   #7
GT66PONY
Thank you!!
Old 04-14-2015, 05:50 AM   #8
C26Pinelake
The respected voice of experience once again offers his great advice ! This man speaks with experience to back it up.
Wayne
C26Pinelake is offline   Reply With Quote
Old 04-14-2015, 06:21 AM   #9
Big hammer
Follow Toms advice you can't go wrong :-) post #6
Old 04-14-2015, 10:45 AM   #10
Tom Wesenberg
Wayne
Please Wayne, no applause.................just throw money!
