Old 04-03-2015, 10:01 PM   #1
lodown2003
Default 1936 coupe water drain tube locations question
Trying to figure out where all my water drains are . Located the ones under cowl below front windshield frame. Found the ones under the rear trunk lid seal also the drain pan for the rear window. Was there a drain location on the inside of the roof, towards the rear where the canvas top insert goes?
lodown2003 is offline   Reply With Quote
Old 04-03-2015, 11:23 PM   #2
Randy in ca
Randy in ca's Avatar
Default Re: 1936 coupe water drain tube locations question
No roof drain. I think the only one you've missed is the one around the cowl vent.
Randy in ca is offline   Reply With Quote
Old 04-04-2015, 08:56 AM   #3
lodown2003
thanks for info
