I'm trying to work through the pros and cons of running these crank journal clearances. I have .003 on #1 & #2' and .002 on #3 with new bearings. Realizing the stated limits is .005 it is foreseen that the increased clearance will reduce my oil pressure. Not a hot engine by any means but in a pickup with lower gears. At this stage I'm temped to bite the bullet and turn the crank to improve the clearance and or look for a 4" crank.
I'm a beginner so looking for expert advice. Thanks! Tim
Tim Downtown, Ca |
Are you measuring with mikes or using Plastigauge to get those numbers? I don't trust Plastigauge, unless it is checked at multiple locations on each journal. My engine had similar clearances and had plenty of pressure.
'52 F-1, EAB flathead |
Good point, before I bought new bearings I did prelim measurements and thought my crank was within a couple thousands.....supprised to see the .003 with plastigage .
I will recheck it.
Tim Downtown, Ca Last edited by CA Victoria; 03-29-2015 at 06:05 PM. |
It's a little more than necessary but if it's in a truck and not driving long trips use 20-50 oil and it will live forever. Walt
Tim Downtown, Ca |
