Old 03-25-2015, 11:06 AM   #1
miff
Default As bell housing
I am getting ready to set up my aa bellhouesing with the s10 t5 trans. I have the right adapter . I have two questions: one I need to make an adapter to use with the original brake and clutch . Aa bellhouesing does not have one . Any suggestions or pictures would be helpful . Two I understand the the input shaft on the t5 is to long to fit the model a flywheel . I have all the pilot bushing , bearing to adapt the input shaft .what I am looking for is the amount to cut off( shorten)the shaft . Or will it work with out any modifications. Thanks for your input. Miff
miff is offline   Reply With Quote
Old 03-25-2015, 11:12 AM   #2
miff
Default Re: As bell housing
I see the my post saids as bellhouesing it's supposed to say A A bellhouseing . Big fingers small keys. Miff
Old 03-25-2015, 11:15 AM   #3
Bob C
The adapter I have came with the brake and clutch shaft.
The shaft screws into the adapter.
Bob
Old 03-25-2015, 11:20 AM   #4
CarlG
CarlG's Avatar
PM sent
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-25-2015, 12:26 PM   #5
miff
Your adapter is for a model a bellhouseing and s10 t5 on the back end . My t5 is a ford bolt pattern is there a web site I could go to ? Thanks Miff
Old 03-25-2015, 12:41 PM   #6
Bob C
My adapter is for an AA bellhousing.
Bob
Old 03-25-2015, 03:19 PM   #7
miff
I see by your picture the adapter .Where are you going to mount the peddles ? What I am looking for is a adapter that mounts to the bottom edge of the bellhousing, comes up where the peddle shaft mounts on top and goes to the top of the bellhouseing . It would look like the standard model a bellhouseing with the brake and cluch peddles shaft on top and the cluch throw out bearing shaft down and to therear of the houseing
Old 03-25-2015, 04:49 PM   #8
Bob C
If you look at the first picture I posted you can see the pedal shaft
screws into the side of the adapter.
Bob
Old 03-25-2015, 05:14 PM   #9
Cape Codder
Cape Codder's Avatar
miff - What is your reason to install a AA bell housing ? Can the A bell housing not be used to attach the t5 transmission?
Cape Codder is offline   Reply With Quote
Old 03-25-2015, 06:49 PM   #10
Bob C
The AA bellhousing is shorter.
Bob
Old 03-25-2015, 06:55 PM   #11
CarlG
CarlG's Avatar
I sent you all this information in a PM, did you read it?
Alaskan A's
Old 03-25-2015, 07:44 PM   #12
miff
The a a bellhouseing is shorter and I don't have to cut into the cross rail on the frame .
Old 03-25-2015, 09:08 PM   #13
Cape Codder
miff - Just trying to learn something here - so I take it you will have a 4speed with sincromesh ? Sorry I didn't ask last time.
