Can you run a 42-48 shift solenoid on 12 volt, being that it is a momentary connection.
I would run the hot wire through a resistor. G.M.
www.fordcollector.com |
I have a new ballast resistor part # D1110-A, for a corvette, is this compatible?
I doubt that a ballest resister will carry the current.I would try the resister designed for heaters or radios. Phil
Try it and see how hot it gets. G.M.
The first generation mopar electronic ignition has a dual ballast resistor ---one or both of them can be used ---series for more ohms ---I have used these to fake out lamp modules when led lightsare retrofitted |
tried a echlin ( napa) VT-6184 12-6 volt reducer, 12.2 volt in 12.2 volts out. does a volt reducer actualy drop voltage or just adjust ohm's.
Only when it is under load will you see a change in voltage, in an open circuit there will be no reduction in voltage
You have to measure voltage across the resistor. It will always show system voltage at the output end but will measure correct voltage across the resistor.
