Old 02-14-2015, 12:04 PM   #1
Terry/Iowa
Terry/Iowa's Avatar
Default Shifting fork pins
I'm rebuilding a shift tower and have a question for anyone that has done so before. As I reassemble I can't figure out how to get the shifting fork pins in. They are supposed to go in from inside the housing so the head will be up when the tower is bolted to the transmission and I have tried feeding them with a bent nosed needle nose and a bent nosed tweezers, but have had no luck getting them started. Is there some secret I am missing?
Terry/Iowa is offline   Reply With Quote
Old 02-14-2015, 12:18 PM   #2
svm99
Default Re: Shifting fork pins
I use needle nose, Vise Grip needle nose, a very small pair of pliers I have, which ever seems to work with the tower I'm working on. I also use a pin the same size to keep the fork aligned with the shaft while I insert the hollow pin from the bottom pushing the temporary pin out as I go and then quickly upsetting the hollow pin very slightly to give me time to place the tower over a drift punch "anvil" to back up the head of the hollow pin while I upset the other end. I use a hollow rivet punch from Synder's to spread the rivet.
This can be trying at times, other times everything just "falls" together. Good Luck.
Paul J.
svm99 is offline   Reply With Quote
Old 02-14-2015, 12:32 PM   #3
Brian T
Brian T's Avatar
I have used the original pins, (practice makes perfect) I now use a roll pin, they have been used for years in manual transmission, for those worried about them falling out they could be safety wired.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 02-14-2015, 12:41 PM   #4
Terry/Iowa
Terry/Iowa's Avatar
Thank you both. I want to use the original style pins if possible so I'll try the vice grip suggestion.
Old 02-14-2015, 12:54 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I also use the original pins ans only spread the end enough to keep it from falling out. I haven't done on in some time, but as I recall, I used a small long needle nose.
