Old 02-13-2015, 08:55 PM   #1
1929
Default Mitchell synchromesh modified transmission
is Mitchell the only one who makes or has the best synchromesh tranny out there?
1929 is offline   Reply With Quote
Old 02-13-2015, 11:00 PM   #2
Anteek29
Anteek29's Avatar
Default Re: Mitchell synchromesh modified transmission
I have read where some Model A's have Chevy S-10 trannys installed in them?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 02-13-2015, 11:12 PM   #3
Chris Haynes
Chris Haynes's Avatar
Then you are becoming a street rod and not a model A.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-14-2015, 05:27 AM   #4
Ed Pitts
Ed Pitts's Avatar
You can use a 1939 Ford transmission.
Ed Pitts is offline   Reply With Quote
Old 02-14-2015, 07:57 AM   #5
1929
I had a 1939 ford standard, the tranny operated the same as the model a.
Old 02-14-2015, 08:50 AM   #6
Brendan
Brendan's Avatar
what? how do you figure?
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 02-14-2015, 08:51 AM   #7
Brendan
Brendan's Avatar
I have a 36 pickup, and the trans operates a lot different then my A
Old 02-14-2015, 09:07 AM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes, in some ways you are very correct however most people don't think about why they are different. The Model-A engine is a slow RPM engine that does not need to be "revved" thru the gears. The flathead V-8 does not make any power/torque at low RPM and therefore the engine RPM must be higher in each gear to compensate. That is where the dogs or synchros play in. A Model-A engine that is within factory specifications does not need to have a synchromesh transmission because the shift speeds are 5 & 15 mph. Even downshifting is not difficult for those who use those speeds as a guide.
In reality, a person will spend less money on completely rebuilding a stock transmission, -and then adding a Stipe IB330 cam and a high-compression head which will have better drive-ability than what they will spend purchasing a new Mitchell synco-ed transmission. On the other hand, some folks old incorrect driving habits are tough to break!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-14-2015, 09:32 AM   #9
1929
sorry, I meant the ease of the shifting Brenan
Old 02-14-2015, 09:37 AM   #10
Patrick L.
Patrick L.'s Avatar
I like the idea of having a tad higher first and second but am not concerned about the transmitter being circumcised. So I'm not sure the extra expense of the Mitchell or the Cling adapter is worth it. Learning how to work an old transmitter is part of the fun of these old monsters, in my humble opinion.
Old 02-14-2015, 09:47 AM   #11
1929
I will just rebuild what I have, I cant justify spending over $1,800 on the Mitchell, they wont sell you the parts, they said machine work has to be done so you have to send it to them.
Old 02-14-2015, 09:58 AM   #12
BRENT in 10-uh-C
There is machine work involved. The majority of money is likely spent on their machining of the gears and making the parts. When you look inside of a Mitchell, you can easily spot what all is different.
BRENT in 10-uh-C
Old 02-14-2015, 11:37 AM   #13
Charlie Stephens
Either you had a 4 speed truck transmission or you transmission needed major work.
Charlie Stephens
Old 02-14-2015, 11:50 AM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
I would spend less than that on a Snyder's 5.5 head and a 3.27 ring and pinion. Then you will have a nice cruiser for driving 45 to 55 MPH without racing the engine.
Old 02-14-2015, 12:49 PM   #15
1929
Id like to get that 5.5 head, I heard if you go higher then that to make sure the engine is in good shape.
