Old 03-05-2015, 11:17 AM   #1
oldbike99
oldbike99's Avatar
Default Front radius rod felt block installation
I am wondering if the felt block is " trapped" under the pin that keeps the radius rod mount bolts from turning, or does the pin stick through the pad?
Also, the replacement pad I have seems quite wide, at 2 3/4 inches, to fit between the bolts.
I am sure, as usual, I am over thinking this!
Paul
oldbike99 is offline   Reply With Quote
Old 03-05-2015, 12:10 PM   #2
Tom Endy
Tom Endy's Avatar
Default Re: Front radius rod felt block installation
This is how I install them.
Tom Endy
Old 03-05-2015, 12:14 PM   #3
oldbike99
oldbike99's Avatar
Thank you very much. That one picture answers my question. The felt block I have is, at least, two times too thick. I wish it was always that easy
Old 03-05-2015, 12:14 PM   #4
CarlG
CarlG's Avatar
Originally Posted by oldbike99 View Post
I am wondering if the felt block is " trapped" under the pin that keeps the radius rod mount bolts from turning...
Yes
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-05-2015, 11:46 PM   #5
1930artdeco
1930artdeco's Avatar
Is there a way to get to the felt pad without taking out the tranny?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-06-2015, 06:30 AM   #6
Steve Plucker
Mike
Drop the front radius rod from the bottom of the clutch housing assembly, then remove the other items...there you will see a hole for which the felt pad can be removed. Install new pad and reassemble.
Pluck
Old 03-06-2015, 07:55 AM   #7
BudP
BudP's Avatar
I cut the back of the felt pad into a circle while leaving the top as a rectangle and just thick enough to put pressure on the pin. The circle slides into the hole.
BudP is offline   Reply With Quote
Old 03-06-2015, 08:52 AM   #8
Joe K
Joe K's Avatar
Doing it all from the outside, and after a radius rod bolt/retainer pin replacement likewise done from outside.
I simply cut the felt into a hockey puck or plug to fit the hole. Placed the felt in the hole and the cast iron rubber ball carrier put on, pushing the felt into the pin.
Yes, there's a little less felt to soak up the dripage - but I reasoned that even a full block of felt would in a short time be to the same condition - mine just a little faster.
Joe K
Shudda kept the horse.
