Old 12-01-2014, 07:25 PM   #1
fishnjim
Default 1940 deuxe hood alignment
any good suggestions on getting the allignmnet right here?
fishnjim is offline   Reply With Quote
Old 12-01-2014, 08:09 PM   #2
TJ
TJ's Avatar
Default Re: 1940 deuxe hood alignment
I align the hood to the cowl and make sure there is a nice even gap between the hood and the body. I then fit the fenders/grille up to the hood. I think if you do a search on this forum there is some very helpful information on this issue.
Old 12-01-2014, 09:23 PM   #3
john worden
john worden's Avatar
This is good.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 12-01-2014, 09:49 PM   #4
Kube
Kube's Avatar
I start the front sheet metal alignment only when I am completely satisfied with the door alignment. If you're restoring a convertible, it's a MUST that the top be completely installed (in the up position) and functioning as well.
Running boards are not on the vehicle at this time. It is FAR easier to install them later and adjust the rear fenders to the boards.
It is in my opinion, imperative that the hood be installed and aligned to the cowl prior to any fender(s) / grille work is installed. Take your time at this step. It is important that you have good hinges and springs. There should be no wear at any of the pivot points. If there is, the adjustments will be (more) difficult at best and the alignment will not last.
Be careful that the gap is even from side to side both along the top (between the hood and top of the cowl) and each hood side. Be certain the same amount of gap exists between the hood and the cowl. The height of the hood should be even with the cowl. Remember that a persons eye will be drawn naturally to the side of the vehicle and especially to the straightness of the trim and body line. It is imperative that these lines are straight! Bottom line -- the hood MUST BE CORRECTLY aligned. Take your time and get it RIGHT! Before moving on tighten all attaching points. There should be no need readjust the hood later.
Prior to installing the fenders I elongate and enlarge the four clearance holes that will be used to bolt the fender to the lower cowl.* Also at this time I enlarge the four holes in the front of the fender that the grille will later bolt through.*
The grille should be a complete assembly PRIOR to installation. This is important as there is no allowance for adjustment within the grille assembly. Originally the stainless strips at each side of the grille (Deluxe only) were stapled to the sheet metal louvers. Doing this makes the installation a bit neater and positively easier. On concourse vehicles be certain to use round wire staples. Flat staples were not used in 1940.
Now it's time to install the inner fender panel to the respective fender. Prior to this installation enlarge the clearance hole at the bottom (near center) of the inner fender panel.* This hole will be used later to bolt the inner fender to the frame directly next to the brake hose bracket. Be certain to enlarge the correct hole. Of the two holes in this area one will contain a grommet while the other is intended as a clearance hole for the fastener. There is a caged nut on the inner frame to accept this bolt/washer assembly. Bolt the inner panel to the fender at the top using the special flat carriage bolts. Tighten all securely. On concourse vehicles a thin webbing material is required between the fender and inner panel.
Now's the fun part!
WITH HELP, install a fender / inner panel assembly. Loosely install the nut/bolt assembly through the 'Y' brace to the inner panel. Install (snug -- not tight) the four bolt / washer assemblies at the lower bottom of the fender to the caged nuts within the cowl. Now install the other fender.
Again, WITH HELP, using the eight nut / bolt / washer assemblies install the grille assembly between the two fenders. Again, snug -- not tight.
Now's the (not) fun part!
There is no easy way to do the remaining aligning. However, patience is an absolute must! Do not be surprised if this takes two, even three evenings. I tend to 'walk away' when I become frustrated.
Slowly and methodically push / pull / tug on the fenders and grille assembly until you are somewhat satisfied with the alignment. Keep a careful eye at the horizontal gap between the hood and the grille (top) as well as the vertical alignment of the hood to grille.
Tighten the bolts at the grille / fenders just a bit more at this time. Recheck all the gaps. If you remain satisfied move on to the four bolts at the lower fender edge / cowl. Tighten these a bit more too. Do the other fender.
Continue to recheck all the gaps after tightening each area.**
Tighten the bolt / nut assemblies at the 'Y' brace. Again, check all of the gaps to be certain nothing has moved.
If you remain satisfied with the entire alignment it's time to tighten all fasteners securely. If you are not satisfied you should be able to push / pull at the fenders as thus far the attachment points are only snug. Remember, "snug -- not tight"? This allows the sheet metal to be moved a bit into place and hold it there prior to firmly securing the fasteners.
If this tightening causes the fenders to pull in too much it is practical to install a thin washer between the fender panel(s) and brace. On reproduction panels I've found it necessary to enlarge this hole (inner panel) just a bit.
Lastly, install the lower radiator air deflector. It may be necessary to enlarge a hole or two in this pan. Not to worry -- all are covered by the proper fasteners.
* I enlarge the holes to 1/2" and elongate approximately 1/8" on either side of each hole. The elongation should follow the curve of the fender. Remember that all these holes will be completely covered by the correct body washers.
**If any gap should change after a specific area has been secured you know with certainty which area caused the effect. You may need to elongate a hole or two in that area a bit more. There should be NO binding at any attachment points.
Mike "Kube" Kubarth
Old 12-02-2014, 06:23 AM   #5
fortyfords
fortyfords's Avatar
Kube, That is wonderful and helpful advice. I have one thing to ask, on my forty, when I would start to lower the hood, when the hood got to a certain point, like 2/3 the way closed, the hood would drop into position on the cowl and then when I closed the hood the rest of the distance, the hood would be perfectly aligned. Have you ever noticed this happening on any other forty? I would sure like to meet you as I can tell that you love forties like I do.
fortyfords is offline   Reply With Quote
Old 12-02-2014, 10:56 AM   #6
19Fordy
19Fordy's Avatar
fishnjim: Type the words 40 ford front sheet metal into the search box and you will find lots of very helpful info. including more from "Kube" who is a recognized 40 Ford expert.
Old 12-02-2014, 11:20 AM   #7
Karl Wescott
Karl Wescott's Avatar
Kube, possibly the best explanation I have read on aligning a 1940. Thanks.
Karl Wescott is offline   Reply With Quote
Old 12-02-2014, 12:57 PM   #8
1931 flamingo
1931 flamingo's Avatar
Years ago in Street Rodder mag there was a detailed procedure (with pictures) on how to align hood and sheet metal on a "40 by Frank Oddo if I remember correctly. Maybe someone could refrence it??
Paul in CT
Old 12-02-2014, 01:00 PM   #9
19Fordy
19Fordy's Avatar
Here's the Street Rodder Magazine info. 1931 is referring to.
https://www.fordbarn.com/forum/showth...etal+alignment
Old 12-04-2014, 04:00 PM   #10
911 STEVE
Kube, another question for you on my 40 tudor. I had it painted & reassembled at a great body shop 2 years ago. great gaps, very happy with the work. It has fiberglass running boards, the only glass on a good steel body. since then I have found a good pair of steel boards that need to be re-covered. after I re-cover them, will the installation require much adjustment?? I'd like to do it myself, but if there's a ton of adjustment involved I would be tempted to let the body shop do it. AGAIN, THANKS FOR ALL THE HELP YOU HAVE PROVIDED US OVER THE YEARS, STEVE
911 STEVE is offline   Reply With Quote
Old 12-04-2014, 07:24 PM   #11
Kube
Kube's Avatar
Steve, I am about 99% confident that installing authentic boards will be a breeze and require NO alignment tweaks.
I leave the boards off when aligning the front clip as it is another thing that can add to the frustration level. GRRR.
Are you going to paste on a set of covers or have Acuff vulcanize them?
Have a great Christmas!!
Old 12-04-2014, 08:11 PM   #12
fishnjim
thanks so much for the help! i have printed these off and Dad and I are gonna try this weekend!
Old 12-05-2014, 12:11 PM   #13
911 STEVE
on the glass boards, I had the body shop install ones I had from Vintique. he said they went on pretty smooth. the steel boards need some minor straightening so I may just have him glue a set of Vintique covers on when he's done with the metalwork.
