Old 11-07-2014, 02:58 PM   #1
larry/Texas
Default Fuel Pump Push Rod Bushing
I need to replace the push rod bushing in an operating engine. How do you pull the existing one out and replace it in a late 21 stud engine? Any help and/or advice would be greatly appreciated.
Thanks
larry/Texas is offline   Reply With Quote
Old 11-07-2014, 03:13 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Fuel Pump Push Rod Bushing
I gotta ask.What's the reason for replacing?
Old 11-07-2014, 03:31 PM   #3
larry/Texas
The rod is very loose in the bore and I understand this is a cause for reduced oil pressure.
Old 11-07-2014, 03:37 PM   #4
Andy
They are always loose in the bore. There is no oil pressure on that cam bearing journal where the push rod runs. It just gets spray/ mist from oil getting out of the top of the oil pump. You can't loose oil pressure as there is none there. The bushing can not be removed without pulling the cam. They are driven down into the bearing cavity. It will be fine.
Andy is offline   Reply With Quote
Old 11-07-2014, 03:44 PM   #5
Bruce Lancaster
Absolutely correct! On other aspects of looseness, as long as it stays in between the cam and the cup on the pump it will be fine. New bushing can wait until engine needs an overhaul.
Also, on oil pressure, before you even worry remove one of the plugs or sender unit at back of engine and temporarily install a mechanical tube pressure gauge...there are too many imponderables in ancient electric gauges until they are verified with a mechanical gauge.
And remember...flatheads can survive with the barest flicker of movement down at the bottom of the pressure scale.
To emphasize...you can DISCARD the pushrod and not lose oil pressure. I have heard of cases of it causing some blue smoke thus (no umbrella put on hole) because of allowing more of the general oil fog into valve chamber, but it cannot drop pressure.
Old 11-07-2014, 07:14 PM   #6
Ken/Alabama
Not true. I don't even have a pushrod in mine cause I have a electric pump. Been that way for 20 yrs and many miles.
Old 11-07-2014, 07:52 PM   #7
JSeery
JSeery's Avatar
The oil goes around the outside of the bushing.
Old 11-07-2014, 09:23 PM   #8
Ralph Moore
Ralph Moore's Avatar
But on the 8ba this is an issue right?
Ralph Moore is offline   Reply With Quote
Old 11-07-2014, 10:02 PM   #9
flatjack9
flatjack9's Avatar
No.
Old 11-07-2014, 10:13 PM   #10
Binx
Originally Posted by flatjack9 View Post
No.
Yes
http://fordbarn.com/forum/showthread.php?t=99948
Lonnie
Binx is offline   Reply With Quote
Old 11-07-2014, 10:47 PM   #11
JSeery
JSeery's Avatar
Put a plug in mine but it is a 59a.
Old 11-11-2014, 08:56 AM   #12
larry/Texas
Thanks for the information and discussion. I will not wporry about it until I need to do an overhaul. Thanks again
Old 11-11-2014, 11:38 AM   #13
El Rat
To answer your question: Tap the bushing and pull it out. If you're worried about the debris use a vacumn while tapping.
El Rat is offline   Reply With Quote
Old 11-11-2014, 12:22 PM   #14
Andy
Very bad advice!!!
The bushing is extreamly thin walled. Any tap will just cut it off when tapped. It takes a special thin ridged punch to get them out by driving them down.
Old 11-11-2014, 12:40 PM   #15
JSeery
JSeery's Avatar
Also, something has to be there, so if you remove the bushing you have to install a plug. The bushing sets in the center of the oil galley.
Old 11-11-2014, 02:31 PM   #16
19Fordy
19Fordy's Avatar
After installing an electric fuel pump, I removed my 8BA fuel pump rod and the oil pressure did not drop. I did not remove the bushing nor plug it. Overcame mist problem by extinding a rod with a little cover that covers the bushing when oil filler cap is screwed down. Been like that for 20 + years. No problems.
Old 11-11-2014, 02:53 PM   #17
JSeery
JSeery's Avatar
Yep, the oil flows around the bushing, not the rod. It is only if you remove the bushing that you will have major oil pressure issues. The oil coming out of the fuel pump rod hole on a 59a block is just oil splash. On the later blocks there is a small bleed hole that oils the fuel pump rod. If you do not plug it you will loose some oil pressure down stream from it. This may not show up as lower oil pressure on the gauge because it is up stream, but it will reduce the volume of oil down stream from the bushing. And it is true that flatheads can get by on fairly low oil pressure.
Old 11-11-2014, 07:07 PM   #18
flatjack9
flatjack9's Avatar
I don't believe this for a minute. Any change in restriction to oil flow will be seen at the gauge. Open up bearing clearance downstream and you will see a loss in pressure at the gauge. And removing the pushrod will make no measurable difference.
Old 11-11-2014, 07:44 PM   #19
JSeery
JSeery's Avatar
I agree flatjack, the claim was that with the fuel pump rod removed there was no drop in oil pressure. I was just trying to think how that could be. On a 59a there wouldn't be any pressure loss, but on a later model there would be. So, I will stop speculating and stick to the facts! These has to be some pressure loss on a late model engine with an open hole in the oil galley. Not sure how much it would show up on the gauge, but that hole is in the same range as the oil bypass restrictor.
Old 11-11-2014, 11:05 PM   #20
flatjack9
flatjack9's Avatar
Remember that the pushrod is not a tight fit in that bushing, so would hardly restrict any flow from that hole. So there would not be any difference with or without the rod. However it would definetly cause a more oil to spray around in the valve chamber.
