Old 08-28-2014, 05:15 PM   #1
dgkipp
Default hold down for mallory ditributor
have a new Mallory distributor would like to install on my 8ba engine with stock 49-53- timing cover. I have mcf heads on the engine, what can I use to hold the distributor in place? Thanks for the help.
dgkipp is offline   Reply With Quote
Old 08-28-2014, 06:35 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: hold down for mallory ditributor
If the mallory is made for the flathead it will bolt down with a lip just like the old one did.
If not put a rag in the cover hole , then drill the cover in a couple upper spots and tap 8 / 32 . Then use short 8/32s to lock the distributor after you set timing. Doesnt take much to hold one as they dont drive any accesorys....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 08-28-2014, 08:56 PM   #3
19Fordy
19Fordy's Avatar
It will look like this. I used one 1/4-28 socket head cap screw and a 1/4 in. tall collar so as to keep the Mallory dist. at the proper height so the gears mesh correctly as when using the original stock heads.
Old 08-28-2014, 11:44 PM   #4
wga
wga's Avatar
DG - I am using the stock hold down on the Mallory. Works fine. The setup that
Fordy is clean and simple. KISS principle at work there.
PS the Mallory I am using was set up by Bubbas.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 08-29-2014, 06:48 AM   #5
dgkipp
Thanks for the quick response guys that really helped me
Old 08-29-2014, 07:03 AM   #6
V8 Bob
V8 Bob's Avatar
I think the problem here is MCF heads are all early style with no provision for a late distributor hold down, so the modification Bubba's and 19Fordy's describe is necessary.
