Old 08-10-2012, 02:46 PM   #1
sconnors
sconnors's Avatar
Default Hood alignment & adjustment
Noticed today that the hood on the passenger's side has a much wider gap than the hood on the drivers side. However the front of both sides seem to line up. Is there any way to correct this? The passenger side front is hard to get the latch on even though it seems lined up. I've attached some pictures.
Any help would be greatly appreciated
Scott
sconnors is offline   Reply With Quote
Old 08-10-2012, 06:20 PM   #2
springerpete
springerpete's Avatar
Default Re: Hood alignment & adjustment
I have just been thru that problem myself. My correction was to take the sag out of the frame. Yours could be that or a worn out body block on that side. Might give both of these a look-see.
springerpete is offline   Reply With Quote
Old 08-10-2012, 06:32 PM   #3
ctlikon0712
ctlikon0712's Avatar
Mine has the problem as well. I've read on FordBarn that the sag typically is where the rear motor mounts are on the frame. Good luck.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 08-10-2012, 06:33 PM   #4
Fred K-OR
Fred K-OR's Avatar
I have a similar problem and I think springerpete has it identified. The only other problem could be a radiator that is set up to high.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 08-10-2012, 06:57 PM   #5
700rpm
700rpm's Avatar
I have had some luck loosening the body bolts on my pickup and shifting the body. What you want to do is change the centerline of your rear hood bracket. There's an article in "How to Restore Your Model A Vol II" that addresses this trouble.
Ray Horton, Portland, OR
Old 08-10-2012, 11:32 PM   #6
columbiA
Looks like the rear hood hinge bracket has to be mved to the left.Loosen the rear screws & the caged nuts will allow the bracket to be moved a bit.You can also add a shim or two under the bracket to raise it if gap is wider at bottom.
columbiA is offline   Reply With Quote
Old 08-11-2012, 09:06 AM   #7
TinCup
TinCup's Avatar
First thing to try is to adjust the upper radiator support rods to try and line it up better. You can only get so much adjustment if the frame is sagging as had been mentioned. You will need to loosen upper radiator hose to allow the radiator to move then you tighten the rod on the side with the larger gap.
TinCup is offline   Reply With Quote
Old 07-07-2014, 07:36 PM   #8
Gddecolret
Thank you for the*informative*posts.
Gddecolret is offline   Reply With Quote
Old 07-07-2014, 11:04 PM   #9
TerryH
TerryH's Avatar
The radiator can also be adjusted slightly; if it is mis-aligned, there will be a larger gap one side, smaller on the other.
TerryH is offline   Reply With Quote
Old 07-08-2014, 07:45 PM   #10
Tinbasher
Tinbasher's Avatar
From what I can see, the body block on the passengers side has collapsed and you'll have to shim up the front cowl bolt to lift that area. It should swing the hood to the even the gap top to bottom and side to side. I'd check the frame for a sag at the rear motor mount. The easiest way is to place a straight edge on the top edge of the frame rail at the motor mount. If there's a gap on the top between the frame and the straight edge you have a sag!! Anything over 1/4" (Max) should be straightened.
The Old Tinbasher
Tinbasher is offline   Reply With Quote
Old 07-09-2014, 04:17 AM   #11
Arlen
Arlen's Avatar
I was going to suggest checking the very front body shim. Looks like a thin rubber donut. Adding/subtracting those can make a monstrous change in hood fit. Keep in mind that if too many shims get added, the hood latch only stretches so far.
DMAFC
Arlen is offline   Reply With Quote
