Old 06-20-2014, 03:49 PM   #1
hardtimes
hardtimes's Avatar
Default 'hoghead' ?
Awhile back , I got a 4 speed trans out of a rodded A pickup. Complete with what is known as a hogshead bellhousing. As fate would have it, just got a 3 speed trans out of a rodded A pickup. Bell looks same/same on both.
My inquiry is ...did Ford put 3 and 4 speed trans in A pickup and did both have hoghead bells ?
Attached are some pictures of the two mentioned A transmissions. I was wrong in stating that the two bell housings are SAME ! Four speed bell is near 5" deep and three speed bell is near 6 1/2" deep. Throwout bearings are different with four speed looking larger/stronger size and four speed is attached with SIX large bolts, whereas three speed is attached with four bolts. However, they both have same holes / pattern for attaching to flywheel cover.
My question now is ....can either or both of these bell housings be used on A and/or B engines ? And, which if any is 'hogshead' ?
Last edited by hardtimes; 06-25-2014 at 03:25 PM. Reason: corrections/clarification.....
Old 06-20-2014, 04:49 PM   #2
Bob C
Default Re: 'hoghead' ?
There was a heavy duty three speed, open driveline, with a hogs head.
Are your transmissions Model A or later?
Bob
Old 06-20-2014, 05:55 PM   #3
James Rogers
James Rogers's Avatar
Pictures?
James Rogers is offline   Reply With Quote
Old 06-20-2014, 06:13 PM   #4
redmodelt
redmodelt's Avatar
The "hogshead" is a Model T term for the transmission cover and is nothing like the A bell housing. The 4 speed would need to use a truck bell housing which is not the same as the 3 speed housing. The truck/4 speed housing and transmission can be used in a car or pickup. The bolt pattern where the transmission bolts to it is different between the 3 and 4 speed.
Don't know if Ford ever supplied a 4 speed in a pickup but there are later conversions to get the real low 1st gear.
Old 06-20-2014, 08:48 PM   #5
Bob C
Here is a HD 3 speed and a 4 speed hogs head.
Bob
Old 06-21-2014, 12:59 AM   #6
hardtimes
hardtimes's Avatar
Originally Posted by James Rogers View Post
Pictures?
Thanks guys ! Will add pictures of both trans...side by side tomorrow , if time allows.
BTW, both trans came out of 1929 Ford Model A pickups.
Old 06-21-2014, 01:05 AM   #7
hardtimes
hardtimes's Avatar
Interesting information. Maybe I'm IDing wrong. Maybe pictures tomorrow will help.
Old 06-29-2014, 03:59 PM   #8
Bob C
In the first picture the one on the left is the AA 4-speed and the one on the right is
an A 3-speed. I have seen both of the bell housings used for installing 5-speeds
or 4-speed OD transmissions. I think the AA bell housing is preferred because
it gets the trans a little farther ahead of the cross member.
Bob
