Old 06-12-2014, 07:22 PM   #1
MurphyJ
Default Throw out bearing lube question
Time to lubricate my a's throw out bearing and i am concerned about over lubricating it. How many strokes on my grease gun?
1? 2? 3? More? Thanks for your suggestions as i certainly do not want excess grease in that location but do want enough for a couple of thousand miles.
MurphyJ is offline   Reply With Quote
Old 06-12-2014, 08:19 PM   #2
machine girl
Default Re: Throw out bearing lube question
If its a modern bearing its sealed, (no grease) you will just pump grease in the bellhousing and if it gets to your clutch you will have a new problem. 1 /2 pump will do the bearing collar.
machine girl is offline   Reply With Quote
