Old 06-07-2014, 09:09 AM   #1
Steve Plucker
Default Correct wire size for the Distrubutor Bus Bar Support Assembly
What is the correct size wire (gauge) used within the distributor on the A-12148 Distrubutor Bus Bar Support Assembly?
This is the lower round flat plate below the Breaker Plate.
Thank You.
Pluck
Old 06-07-2014, 11:10 AM   #2
Steve Plucker
Default Re: Correct wire size for the Distrubutor Bus Bar Support Assembly
Originally Posted by 1930 coupe View Post
The wire is 3 1/2" long, the wire for the 28 forged upper plate is longer at 4 1/4" long. I do not know the wire gage.
Thanks 1930 coupe...I meant gauge.
It is hell getting old!
Pluck
Old 06-07-2014, 11:13 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I don't know the original gauge of the wire, but it must be very fine strands, so it's very flexible.
100 or more strands is what you'll need.
Old 06-07-2014, 11:34 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
I have used both 18 gauge, and 16 gauge, but more important than either gauge is the strand count, 40 years ago I put in some 18/65/36 ---18 gauge with 65 strands of #36 copper wire, I have also used 16/105/36
Most of the repro plates have regular primary wire--18/7/24, this breaks easy when flexed, not much fatigue resistance to bending
The original wire probably had a lower strand count, but I didn't want to ever have a failure
copper stranding chart---
http://www.maneywire.com/documents/C...ng%20Chart.pdf
I will try digging in the junk box and see if I can come up with something original to compare
Old 06-07-2014, 11:40 AM   #5
d.j. moordigian
d.j. moordigian's Avatar
Steve,
I sent this to Tom Wesenberg about a year ago.......http://www.sharprc.com/....
he thought the wire look good, and so do I. I checked a distributor here at work,
it had a "field fix" that my Dad and I did in '66. The wire measures out @ about
14 gauge and it worked OK.
Hunt around in the sight, they sell just the wire,I think, by the foot....nice stuff.
*...this will help with the AMPS.....http://www.powerstream.com/Wire_Size.htm....
I thought Tom said about 6 amps for the coil.....Tom??
d.j. moordigian is offline   Reply With Quote
Old 06-07-2014, 11:54 AM   #6
Bob C
This is on Vince's site http://www.fordgarage.com/pages/adistlowerplate.htm
Bob
Bob C is online now   Reply With Quote
Old 06-07-2014, 12:01 PM   #7
Steve Plucker
Thanks Guys!
Ahhhh...The wonder of Ford Barn'ers!
Pluck
Old 06-07-2014, 12:49 PM   #8
Tom Wesenberg
My slant pole coil draws 4 amps when it's on full time, but only 1 to 1 1/2 when the engine is running.
