Old 09-21-2016, 06:58 PM   #1
cw253748
cw253748's Avatar
Default rpm vs. mph
Hi guys. I have a 31 Tudor with I'm guessing a 3.78 rear end. I have a tachometer on the car and I rev at 2500 rpm's at 45 mph. Is this correct? I doubled checked the speedometer with a gps and it is dead on. There are 19 inch tires on and fresh rebuild engine. No over drive.
Thanks for your input.
Chris
cw253748 is offline   Reply With Quote
Old 09-21-2016, 07:25 PM   #2
ryanheacox
ryanheacox's Avatar
Default Re: rpm vs. mph
Seems high. 45mph is just shy of 2000rpm with everything stock and a 3.78 rear end. That would even be high with a 4.11 rear. I put the numbers in to a calculator and 2500rpm would be 58mph with 3.78's and 54 with 4.11's. Maybe the tach needs to be calibrated?
Old 09-21-2016, 07:35 PM   #3
CarlG
CarlG's Avatar
I was thinking it was high also. I figure around 2,200 @ 50mph. 3.78, 5.50R19.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-21-2016, 08:26 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Measure from the road to the center of the hubcap. This is your rolling radius, which will be less than the radius on the rest of the tire. Double this measurement for the rolling diameter, then multiply by pi for the distance the car travels with one tire revolution. Now divide that number into 5280 to get how many revs the tire needs to make to go one mile. now multiply that number by the rear end ratio 3.78 and you will know how many revs the engine needs to make to go one mile. So, if you are going 60 MPH, that's the RPM the engine would be turning. At 45 MPH the engine would be turning 3/4 of that number.
I'll measure my 28 and do some calculating.
I just measured my 28 and have 14.5" from the floor to the center of the axle, so 29" diameter X 3.1417 = 91.11" per tire roll. Divide that into inches per mile (63,360) = 695.423 tire turns per mile X 3.70 rear end ratio = 2573 engine revs per mile. So at 60 MPH which is a mile a minute, the engine would be turning 2573 RPM, and at 45 MPH it would be 2573 X 3/4 = 1930 RPM.
With a 3.27 rear end the engine would be turning 2270 RPM at 60 MPH, and at 45 MPH the engine would be turning 1702.5 RPM.
Old 09-21-2016, 09:23 PM   #5
cw253748
cw253748's Avatar
Thanks Tom. I will measure my tire tomorrow and check my results.
Old 09-21-2016, 09:28 PM   #6
TinCup
TinCup's Avatar
Wow that is some hard math!
TinCup is offline   Reply With Quote
Old 09-21-2016, 09:47 PM   #7
tbirdtbird
gee wiz Tom now we have to even do math too? You are a tough guy
'31 180A
tbirdtbird is offline   Reply With Quote
Old 09-21-2016, 09:55 PM   #8
C26Pinelake
What is the reason you have a tachometer? Wayne
C26Pinelake is offline   Reply With Quote
Old 09-21-2016, 10:11 PM   #9
kenparker
kenparker's Avatar
calculating mph/rpm's is math. Stopping distance is physics. Mixing paint is chemistry. Shucks guys I thot model A's were 'posed to be fun. ken
kenparker is offline   Reply With Quote
Old 09-21-2016, 10:18 PM   #10
Dick Steinkamp
Dick Steinkamp's Avatar
I like how Tom has thought through the math on this. But for us lazy guys, here is an on line calculator to do the grunt work for us...
http://bgsoflex.com/rpmmph.html
With it, you can compute the RPM to attain a given MPH or the MPH resulting from a given RPM.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 09-22-2016, 10:23 AM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Dog here,
Iffin' you measure the inches around the tire, convert 5,280 feet, into inches, DIVIDE the LITTLE number into the BIG number & it'll tell you how may turns it takes to run a MILE BUT, the centrifiugal force causes the tire to "grow", SO, the calculations are "out the window"--BACK to the "drawing" board OH CRAP, the battery in my CALCULATOR jist "DIED"
Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 09-22-2016, 10:37 AM   #12
Rex_A_Lott
Some tachs have a wire or two you have to clip to set them up for 4, 6 or 8 cylinders. Someone may have not configured yours for a 4 cylinder.
Good Luck
Rex_A_Lott is offline   Reply With Quote
Old 09-22-2016, 11:37 AM   #13
d.j. moordigian
d.j. moordigian's Avatar
Geezz Tom...you made my head hurt......but you'r figures are correct....lol
I carried this too every track I raced at(engine man) to figure for gear changes since 1973,...it works and it's accurate. Ya!...I still use it to this day!
d.j. moordigian is offline   Reply With Quote
Old 09-22-2016, 05:26 PM   #14
Special Coupe Frank
Special Coupe Frank's Avatar
VERY cool !
Special Coupe Frank is offline   Reply With Quote
Old 09-22-2016, 06:01 PM   #15
Licensed to kill
Licensed to kill's Avatar
Chris
No that is not correct. RPM is correct for "revolutions per minute". RPM's is....well i don't know what that would be. Just sayin'. One of my goofy little pet peeves.
Licensed to kill is offline   Reply With Quote
Old 09-22-2016, 06:23 PM   #16
CarlG
CarlG's Avatar
Here's your badge to go along with your license:
Alaskan A's
Old 09-22-2016, 06:39 PM   #17
sphanna
sphanna's Avatar
If you have 19" rims and Firestone 450/500 tires you will get 14,4" from center of hub to floor. Any other tires on 19 in wheels will be so close it will be negligible. Buy the way , Tom W. is correct in everything he said about the post. It is not complicated at all. But if you prefer, There is a very easy constant that will get you within 1 mph. That is to take your speed in mph and multiply it by 44 and you will have it. I was not able to calculate for 21" because I had not 21" wheels. Now I know since Tom has measured for us. Use his method and you will not go wrong. It is perfect.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 09-22-2016, 08:17 PM   #18
eagle
eagle's Avatar
Originally Posted by BILL WILLIAMSON View Post
Dog here,
Buster T.
That's not all Bill. The tire patch that is on the ground compresses a bit, and the part NOT on the ground stretches. Very complicated formula. You need the get the specs from the tire manufacturer, then plug it all into a formula as long as your arm....and don't forget about slippage of the driven tire... OUCH! Yeah, makes my head hurt!
Old 09-22-2016, 09:10 PM   #19
cw253748
cw253748's Avatar
I just did Tom's math. I have 14.25 to center of hub cap with 19 inch tires. I get 2675 at 60 mph and 2006 at 45 mph with a 3.78 rear end
If I substitute a 4.11 rear end in the equation I get 2908 at 60 mph and 2181 at 45 mph. So either I have a 4.11 rear end or the tach is off. It is a Westach from Snyders.
Old 09-22-2016, 09:24 PM   #20
Licensed to kill
LOL. perhaps you missed these in my previous post ""
