Old 05-29-2014, 04:34 PM   #1
Relvis P. Johnson
Default 12 volt Issues
What do I need to do to put my old distributor back into the engine after I converted to 12 volts? My nu-rex is giving me trouble and I want to see if the problem of rough running under load is in the ignition system. I put the old distributor back in and used the condenser off of the nu-rex, but it shorts out. I've missed a step or two I'm sure. Does anyone have any suggestions?
Relvis P. Johnson is offline   Reply With Quote
Old 05-30-2014, 04:16 AM   #2
clee2
Default Re: 12 volt Issues
Make sure you are going from negative of coil to a 6v resistor then to the old distributor. If you do not have the resistor then you are sending too much voltage to distributor points.
clee2 is offline   Reply With Quote
Old 05-30-2014, 06:45 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
Except for the coil the ignition system doesn't care.
