I have this NOS Genuine Ford Steering Sector, but I am confused as to the year. I am hoping that some Fordbarners know more than I do about it.
Using the Green Book, I thought that I could figure it out, but it is confusing. The things that are confusing are; ..... There are two Part Numbers for 1933-1934. One for a 13-1 Ratio and one for a 15-1 Ratio. ..... 1935 has it's own Part Number. ..... 1936 has it's own Part Number. ..... The big trucks have their own Part Numbers. Can anyone recognize which sector this is ? Thank you, MIKE ![]() CLICK ON PHOTOS TO ENLARGE - Twice |
I think it is 35 or 36. Does it have a number stamped on the center tooth? 15 is 35 and 17 is 36.
Mike it looks like a 34 as well ,the wider spline is in line with centre of the teeth. theres not a lot between 34and 35
#4 | |
![]() Quote:
By golly, I looked and it does have a "15", stamped on the backside of the center tooth ! So, that means that it is for my '35. Do you know if it is the same for 1934 ? Thank you, MIKE ![]() |
34 and 35 are different. The teeth are slanted in different directions and the 35 shaft is shorter.It is a 35 shaft.
#6 | |
Thank you for sharing this information ! I appreciate it very much ! MIKE ![]() |
