Old 09-14-2010, 11:59 AM   #1
mrtexas
mrtexas's Avatar
Default MaxJax 2 post car lift
I got my 28 RPU up on the MaxJax today:
So far so good but I had to make a custom post(standard post is on the left, custom on right) for the end of the arms as the Model A frame is way up inside the body as compared to a modern car.
Today is just a test run. Next on my list of projects is installing a new gas tank in the 63 Corvette and then on to fuel injection.
After that, install the rebuilt engine, 39 transmission and Mitchell overdrive in the RPU. Hmm, complete new drive train!
So far I'm very happy with the MaxJax. It takes up a lot less room than a 4 post lift and can be stored away if desired.
mrtexas is offline   Reply With Quote
Old 09-14-2010, 12:05 PM   #2
Mitch//pa
Default Re: MaxJax 2 post car lift
quote((So far so good but I had to make a custom post for the end of the arms as the Model A frame is way up inside the body as compared to a modern car((((
i remember hearing that somewhere before
Old 09-14-2010, 12:25 PM   #3
fordcragar
fordcragar's Avatar
I have two Rotary lifts and have to use the longest posts from both lifts to raise a Model A. Even with them, I have to use a couple of 2x4's as well to pick the car up to clear the running boards This winter I'll make some custom posts to help the process.
fordcragar is offline   Reply With Quote
Old 09-14-2010, 07:27 PM   #4
Bill Steiner
I have Rotary lifts and i use the posts for PU trucks . They work good on model A. Bill
Bill Steiner is offline   Reply With Quote
Old 09-15-2010, 11:42 AM   #5
Dave Pratt - IL
Interesting lift. Without cables between the two posts (like a typical 2 post lift), how are the two sides synchronized?
Dave Pratt - IL is offline   Reply With Quote
Old 09-15-2010, 12:32 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
I assume they have very long anchor bolts and they must be removed to store the posts away.......correct?
Old 09-15-2010, 01:50 PM   #7
mrtexas
mrtexas's Avatar
The anchor have the threads in them and are about 5 inches long. The bolts are 2 inch x 5/8.
