Old 04-06-2014, 06:03 PM   #1
msmaron
msmaron's Avatar
Default RemFlex Exhaust Gaskets
Just got these gaskets and installed them. They are designed to compress 50% and ONLY be torqued up to 15#...you can go as high as 25#. The gasket takes the shape of the surface and fills any gaps..They are $35.00 a pair. More information on their site and will report later on. Wondering if anyone else has tried these at all?????
http://catalog.remflex.com
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 04-07-2014, 09:34 AM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: RemFlex Exhaust Gaskets
I am always in favor of incorporating modern technology when it comes to Model A & B engines. I have not tried these exhaust gaskets yet. Please give us an update about how this new gasket works for you.
I have been using McCord steel gaskets because they do not burnout so readily at Cylinder 4. McCord gaskets are getting hard to come by, so I am all ears about the new gasket you are using.
Bob Bidonde
Bob Bidonde is online now   Reply With Quote
Old 04-07-2014, 11:59 AM   #3
Russ Koch
Hi Mark,
Am wondering why you needed these? Were the copper gaskets not good enough? Are you able to use the gland rings? How did you find these guys? Haha, as you can tell I am intrigued and full of questions.
Russ Koch is offline   Reply With Quote
Old 04-07-2014, 04:26 PM   #4
msmaron
msmaron's Avatar
So far I am noticing a very nice seal and good compression on the gaskets. I found them at one of our A Meeting from some other members and was asked to try them. As far as gland rings I do not know the answer to that but so far they seem to be working good and have not problem with any exhaust leak and only torqued to 25#....more later!
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 04-07-2014, 06:10 PM   #5
Duffy1
Later on Ford stop using gland rings .
Duffy1 is offline   Reply With Quote
