Old 01-05-2018, 10:39 AM   #1
Tim Ayers
Default What needs to be done to use a floor starter button
Howdy All:
On my AV8 project, I've decided to go as authentic as I can. What needs to be done to use a floor starter switch like Ford uses? Is it simply just a foot switch that is live with the ignition key or is there more to it?
Thanks,
Tim
Old 01-05-2018, 10:42 AM   #2
skidmarks
skidmarks's Avatar
Default Re: What needs to be done to use a floor starter button
Its live all the time and the wire to the coil is switched.
skidmarks is offline   Reply With Quote
Old 01-05-2018, 10:48 AM   #3
Tim Ayers
Got it. So any foot switch will do.
Old 01-05-2018, 10:54 AM   #4
JSeery
JSeery's Avatar
A look at the wiring diagrams might help you. Remember, the floor starter switch is carring full current from the battery to the starter.
Old 01-05-2018, 11:05 AM   #5
Frank Miller
Frank Miller's Avatar
A 35-36 starter switch will be in series with the battery cable. I think that is what you're trying to do. You need a switch to handle the high current. If you're going 12 volts this will be more than adequate. A solenoid can be mounted in a more convenient spot and then you can use a lighter switch to operate the solenoid.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 01-05-2018, 11:05 AM   #6
HDowse
HDowse's Avatar
My Model T has the floor starter switch which carries full current (no starter solenoid) from the battery to the starter. Lang's has one and a bunch of cables. Here's the switch link:
https://www.modeltford.com/item/5014.aspx
HDowse is offline   Reply With Quote
Old 01-05-2018, 11:10 AM   #7
swanwaco32
There is a reason they went to the push button. I have done it both ways and find the foot operated is a pain..!! Like when you stall the car on a hill or at a stop light??
swanwaco32 is offline   Reply With Quote
Old 01-05-2018, 11:14 AM   #8
Y-Blockhead
Y-Blockhead's Avatar
If that is the case I think I would add a solenoid in the system somewhere. Then only enough current to operate the solenoid goes thru the switch while full current from the battery goes thru the solenoid to the starter.
Old 01-05-2018, 11:17 AM   #9
Tim Ayers
Thanks all. Yes. I have a 12V generator that I've converted to the fan mount style set up, so it will be 12V if that helps.
Old 01-05-2018, 11:21 AM   #10
Tim Ayers
I don't understand this?
Old 01-05-2018, 11:25 AM   #11
JSeery
JSeery's Avatar
He is referring to the fancy footwork required with a clutch pedal, brake pedal, gas pedal & starter switch. It can get interesting, but I learned to drive with this type of setup, just have to learn how to deal with it.
Old 01-05-2018, 11:36 AM   #12
Tim Ayers
OK, that's what I thought. I like it that way for that's what makes it an old car.
Old 01-05-2018, 12:23 PM   #13
jagnweiner
jagnweiner's Avatar
Exactly. My '25 Dodge has a foot starter and I've never had a problem. Of course I also make it a practice not to stall it at stop signs pointed uphill, but that's another issue. It also makes a nice theft deterrent because most people my age and younger would have no idea how to start the car.
Regards,
Scott
'47 Mercury Convertible
'25 Dodge Bros. Touring Car
'63 MG Midget
jagnweiner is offline   Reply With Quote
Old 01-05-2018, 12:30 PM   #14
RobR'35
RobR'35's Avatar
Using the emergency brake eliminates fast foot work too.
RobR'35 is offline   Reply With Quote
Old 01-05-2018, 12:36 PM   #15
Tim Ayers
I guess that was my thought as well. Why not use the e brake to help with this.
Old 01-05-2018, 12:37 PM   #16
Willit Stop
Willit Stop's Avatar
My coupe still has a stomp starter.It's between the clutch and brake peddle.It was there when I bought it ,so I left it there. Most people today wouldn't have a clue as to how to start the car so I think of it as a theft deterrent.
Dependable? Yes. Safe? Not so much.A couple of times I forgot to take it out of first gear and stepped on the button. It's amazing how fast a flathead will start. I got it stopped in time but almost made the garage a little bigger.
Willit Stop is offline   Reply With Quote
Old 01-05-2018, 12:43 PM   #17
skidmarks
skidmarks's Avatar
some had the starter pedal under the gas pedal and you pushed the gas pedal to the floor to start it.
Old 01-05-2018, 12:44 PM   #18
Ed Pitts
Ed Pitts's Avatar
Tim, the bigger issue is where are you going to put it. The first pic is from my 36 and I have a solenoid mounted where the foot starter was mounted. The second pic is from my A V/8 where an F1 steering column is used. The available room in an A is limited but the addition of the V/8 makes it even more so. The third pic is where I mounted my solenoid. It is out of the way and next to the starter.
Ed
Ed Pitts is offline   Reply With Quote
Old 01-05-2018, 12:45 PM   #19
38bill
38bill's Avatar
My '51 Chevy pickup had a foot starter switch. It was kind of awkward but the switch was close enough to the gas pedal that you could activate it with your heel and still hit the gas with your toes to start it when cold. Super low 1st gear so stalling wasn't much of a problem. I would definitely use a solenoid and I would wire it through the ignition switch so the starter can't be activated by accident.
38bill is offline   Reply With Quote
Old 01-05-2018, 12:49 PM   #20
Tim Ayers
Ed
Ed:
Thanks for the pictures. Some interesting questions. It's one a '32 frame so I thinking towards the outer end near closest to the outside of the car. I haven't planned location yet, I'm still in the process of figure it out of that's the way to go. I want to keep it like an old car and not a street rod.
